Monitoring inverter by nagiosxi
Nagiosxii
Post by Nagiosxii »
hi!
please which wizard can i use to monitor an inverter ( this inverser for our parc informatique) ??
my company ask me to do that ,it is possible !
Re: Monitoring inverter by nagiosxi
You are trying to find a plugin that is going to monitor power inverters - is this correct? If this is the case, you can probably use SNMP to do so. I searched the Nagios Exchange for "inverter", and I had 2 hits:
https://exchange.nagios.org/index.php?o ... d=inverter
Once you make sure that the plugin works for you from the command line, you can add a command, and a service to Nagios XI. To see how to do so, please read the document below:
Nagiosxii
Post by Nagiosxii »
okey!!
thank you so much i will follow the document !!
Sounds good! Let us know if you run into some issues.
Nagiosxii
Post by Nagiosxii »
thank youu soo much!!
really you are the first hepful forum i have seen , wish you all the best!!
good continuation
Post by dwhitfield »
Glad to hear it is resolved. I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
