I have the utilisation of my bandwith for one interface ex: 4Mb/s. And my line is 100Mb/s and it is introduce as info. How can I have the percentage of utilisation of my line? It's a data I would like to add in my graph in Nagvis. Thanks in advance
% bandwith
Re: % bandwith
I believe you can view bandwidth (% utilization) in NagVis. Please, check the NagVis documentation here:
http://docs.nagvis.org/1.6/en_US/index.html
Re: % bandwith
Hello
I used nagvis but when I select to show % I have the real value ex:3M and if I select to show bw and % I hav the BW (ex3.25M) but for % I hav "NULL"
Re: % bandwith
leens,
We will do some testing and will get back to you as soon as we find a solution for you.
Re: % bandwith
leens,
There really isn't a great way to do this that makes it super easy for you. However, it looks like you're getting pseudo-percentage numbers anyways as its already out of 100Mbps. However, I've looked into questions like this previously and never could find a decent way of doing it without rerigging the setup.
Nicholas Scott
Re: % bandwith
So there is no way to have in nagios xi or nagvis a % of utilization?
