nagios slow when login
I am currently monitoring around 1k+ host and 5k service.
When i login nagiosadmin it takes around 20sec to login
I have AD user imported.
Kindly assist. Thanks alot
- Former Nagios Staff
Re: nagios slow when login
I think this will help out: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
Also, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
Hi, i have sent you the systemprofile via PM.dwhitfield wrote:I think this will help out: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
I have read before the maximizing performance nagiosxi, should i implement all of them for this issue?
It's hard to say. It really depends on if your disks are faster than your network. If you are on an SSD, then they probably are. If you offload your db to a VM cluster on the same physical disks, then the offloading is not likely to help.s.wiki wrote:, should i implement all of them for this issue?
It also depends on what is going on on the system at the time you log in.
If I were you, the first thing I would start with is the ramdisk and see if you see any improvement. After that, I'd go to any non-critical services that are being monitored and increase the check interval. Fewer checks, means better performance.
You also have some database issues which may be causing some problems. Probably, you should start a new thread for the database issues though. I'm seeing several of the following:
May 24 14:24:49 localhost ndo2db: mysql_error: 'Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed'Re: nagios slow when login
dwhitfield wrote:It's hard to say. It really depends on if your disks are faster than your network. If you are on an SSD, then they probably are. If you offload your db to a VM cluster on the same physical disks, then the offloading is not likely to help.s.wiki wrote:, should i implement all of them for this issue?
Hi ,
Thanks for your reply.
I have configured the ramdisk and repair the databases.
Disable auto-running on performance setting page.
It is still the same ~20 second. I have 2 worker + nagios server so it is 3 servers in total. So the load should not be the problem (i guess).
Currently not using ssd, and offloading db to another VM will be using the same exsi host and same datastore. However this is too much work and i would prefer this to be the last option.
I have tried to login using nagioscore. it login almost instantly.As for nagiosxi, the webpage speed is quite OK, it is just the login takes up to 20seconds.
Is there anywhere i should look for?
Thank you for your help
Lets increase the memory and timeout values that PHP uses and see if that helps the performance while logging in as the nagiosadmin account.
Edit the /etc/php.ini file and change the following from
to
Then add this to the bottom of that file
Save the file and restart Apache for the changes to take affect.
Try that and see if it decreases the login time to the GUI.
max_execution_time = 30
max_input_time = 60
memory_limit = 128MCode: Select all
max_execution_time = 60
max_input_time = 120
memory_limit = 512MCode: Select all
max_input_vars=5000Code: Select all
service httpd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi ,tgriep wrote:Lets increase the memory and timeout values that PHP uses and see if that helps the performance while logging in as the nagiosadmin account.
Edit the /etc/php.ini file and change the following fromtoCode: Select all
max_execution_time = 30 max_input_time = 60 memory_limit = 128MThen add this to the bottom of that fileCode: Select all
max_execution_time = 60 max_input_time = 120 memory_limit = 512MSave the file and restart Apache for the changes to take affect.Code: Select all
max_input_vars=5000Try that and see if it decreases the login time to the GUI.Code: Select all
I have applied the configuration above , it login still takes around 20sec. Is there anywhere i can look for? do you need some of my apache logs?
THanks
i have this error message everytime i login
[error] [client x.x.x.x] name lookup timed out, referer: https://x.x.x.x/nagiosxi/login.php
after multiple attempt to disable /etc/hosts OR /etc/resolv.conf ..finally i found out DNS is the rootcause. but i still need the DNS for my ad/ldap users.
could this because my ipaddress/hostname is not register to the DNS server?
EDIT:
I have add my server into the dns. and now my servername can be resolved. however the httpd still not recognize it.
Kindly assist
EDIT:
[root@imsvm conf.d]# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using 192.168.248.175 for ServerName
[ OK ]
You have mail in /var/spool/mail/root
[root@imsvm conf.d]# nslookup imsvm
Server: x.x.x.x
Address: x.x.x.x#53
Address: 192.168.248.175
[root@imsvm conf.d]# hostname -f
imsvm.abc.bank.my
Kindly assist
First thing, if the Vagios server's FQDN is not setup on your DNS server, add it to DNS or add an entry in the /etc/hosts file like the example below
To resolve this message
You can add the FQDN to the Apache main configuration file.
Edit the /etc/httpd/conf/httpd.conf file and find the following line and change it from
to
Save the file and restart apache by running
That way, the Apache Server will know the name at start up but I think the changes to the /etc/hosts file should fix this as well.
192.168.248.175 imsvm.abc.bank.my imsvmCode: Select all
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using 192.168.248.175 for ServerNameEdit the /etc/httpd/conf/httpd.conf file and find the following line and change it from
#ServerName www.example.com:80Code: Select all
ServerName imsvm.abc.bank.myCode: Select all
The DNS and nagios is not the same server.tgriep wrote:First thing, if the Vagios server's FQDN is not setup on your DNS server, add it to DNS or add an entry in the /etc/hosts file like the example belowTo resolve this messageCode: Select all
192.168.248.175 imsvm.abc.bank.my imsvmYou can add the FQDN to the Apache main configuration file.Code: Select all
Edit the /etc/httpd/conf/httpd.conf file and find the following line and change it fromtoCode: Select all
#ServerName www.example.com:80Save the file and restart apache by runningCode: Select all
ServerName imsvm.abc.bank.myThat way, the Apache Server will know the name at start up but I think the changes to the /etc/hosts file should fix this as well.Code: Select all
I have configured the ServerName ims.abc.bank.my, the error message no more,but the problem is still there
Currently i have commented out my host entry in /etc/hosts as my DNS is working
However i have tried uncommented my host in /etc/hosts, and the slow 20sec problem is still there.Unless i commented my nameserver in /etc/resolv.conf
I have tried login my nagiosxi web using
ip address.
hostname
fqdn.
all have the same error : name lookup timed out, referer
may i know is there anyother way i can look for(other than disable dns because i need to use it)
