Cannot fetch latest NagiosXI RPM using yum
arangel
Post by arangel »
We received the email that there is a new version of Nagios XI available and tried to upgrade it but we're unable to sync the RPM packages from your repo for RHEL6 (The Nagios 5.4.4 RPM is not available when synchronizing the repository at https://repo.nagios.com).
We can fetch https://repo.nagios.com/nagios/6/nagios ... x86_64.rpm directly with wget but it doesn't work when we try to install the package with yum.
We can see that the last time the repo metadata was generated was on April the 14th 2017.
Steps to reproduce:
1. rpm -Uvh https://repo.nagios.com/nagios/6/nagios ... noarch.rpm
2. yum info nagiosxi
3. Only Release 4.3.el6 is available.
Thanks.
Re: Cannot fetch latest NagiosXI RPM using yum
Our developers are looking into this. It should take an hour or so to get it fixed.
Update: It should work now. Try running:
yum clean all
yum update
arangel
Post by arangel »
Yes it works. Thanks for the prompt resolution.
avandemore
Post by avandemore »
Thanks for using Nagios! If you have further issues, please open a new thread or ticket.
Previous Nagios employee
