Bulk Warning Alerts
Issac08
Bulk Warning Alerts
Post by Issac08 »
Hi All,
i am getting the below error after adding cisco switches. kindly suggest . All interfaces got discovered but getting alerts on all interfaces.
no output on stdout) stderr:/bin/sh:- c:line 0 syntax error near unexpected token
Re: Bulk Warning Alerts
Post by dwhitfield »
I suspect you are missing a " or have too many " in your command in XI. Could you please attach a screenshot of how the command is set up in the CCM?
Also, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
Issac08
Post by Issac08 »
I didn't set any command in CCM..
You may need to read the entire document for context, but there is a screenshot on page 6 of https://assets.nagios.com/downloads/nag ... ios-XI.pdf
I would highly suggest going through our manual as it has links to many PDFs such as the one above: https://library.nagios.com/library/prod ... i/manuals/
Can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
