HI!
please i have a question , how can i add protocoles syslog and netflow to my server nagiosxi?? witch wizard can i use for that ??
SYSLOG AND NETFLOW WITH NAGIOSXI
- Former Nagios Staff
Re: SYSLOG AND NETFLOW WITH NAGIOSXI
It really depends on what you want to do. Please be as detailed as possible in your posts. Specifically, please follow the guidelines in https://support.nagios.com/forum/viewto ... f=6&t=1274
Based on the limited amount of information you've given...
For logging I would suggest NLS: https://www.nagios.com/products/nagios-log-server/
For netflow, I would suggest NNA: https://www.nagios.com/products/nagios- ... -analyzer/
