Problem with NagiosQL
tarzan
Post by tarzan »
Hy,
I have a Nagios Core Version 4.1.1 and NagiosQ: 3.2 installation.
It works for months without any problems, but nagiosQL now reports the following error: "Writing of the configuration failed - no dataset or not activated dataset found" and does not allow you to enter new services or hosts in Nagios. Does anyone have any experience on this error?
Thank you
tarzan
Re: Problem with NagiosQL
Post by tarzan »
I found the cause of the problem, the partition was occupied at 50% but the inode was 100% occupied. I have found a lot of small files that I have deleted and I have thus recovered space in the inode. NagiosQL now works regularly.
Thanks for reporting back that you solved the issue.
Shall I close and lock up the post you you?
