New Install - Waiting for database startup
anish
Post by anish »
We installed nagios log server 1.4.4 lst week on monday. we have a setup of one master and 2 nodes.
The installation was successful and we were able to get to the login page. We then pointed out 2400 devices to all 3 nodes and since then the elastic search is not working. If we try to access the UI we get a message as "Waiting for Database startup".
It is running on centos 7.
I did go through the post https://support.nagios.com/forum/viewto ... 37&t=33804 but it is not relevant to me as it is not an upgrade.
One of the other posts you have asked to use OVA which we cant do as we have a hardened OS image we use.
Below is he output for a few commands from master
[root@a-sesklnglsprd1 app]# tail -n50 /var/log/elasticsearch/*.log
==> /var/log/elasticsearch/0d479f31-cd28-4c68-9cc1-dfa8062b15a7_index_indexing_slowlog.log <==
==> /var/log/elasticsearch/0d479f31-cd28-4c68-9cc1-dfa8062b15a7_index_search_slowlog.log <==
==> /var/log/elasticsearch/0d479f31-cd28-4c68-9cc1-dfa8062b15a7.log <==
[root@a-sesklnglsprd1 app]# tail -n50 /var/log/logstash/*.log
{:timestamp=>"2017-05-25T11:10:22.122000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:22.122000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>56, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:112)", "org.jruby.RubyKernel.loop(org/jruby/RubyKernel.java:1511)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:110)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2017-05-25T11:10:22.675000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:22.675000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>35, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:112)", "org.jruby.RubyKernel.loop(org/jruby/RubyKernel.java:1511)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:110)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2017-05-25T11:10:22.688000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:22.688000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>4, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "RUBY.worker_setup(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:79)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2017-05-25T11:10:22.921000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:22.921000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>15, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "RUBY.worker_setup(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:79)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2017-05-25T11:10:23.125000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:23.125000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>56, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:112)", "org.jruby.RubyKernel.loop(org/jruby/RubyKernel.java:1511)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:110)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2017-05-25T11:10:23.676000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:23.677000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>35, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:112)", "org.jruby.RubyKernel.loop(org/jruby/RubyKernel.java:1511)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:110)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2017-05-25T11:10:23.689000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:23.689000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>4, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "RUBY.worker_setup(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:79)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2017-05-25T11:10:23.922000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:23.922000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>15, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "RUBY.worker_setup(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:79)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
{:timestamp=>"2017-05-25T11:10:24.139000+0000", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-05-25T11:10:24.140000+0000", :message=>"Failed to flush outgoing items", :outgoing_count=>56, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:498)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:112)", "org.jruby.RubyKernel.loop(org/jruby/RubyKernel.java:1511)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:110)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
[root@a-sesklnglsprd1 app]# service elasticsearch status
● elasticsearch.service - LSB: This service manages the elasticsearch daemon
   Loaded: loaded (/etc/rc.d/init.d/elasticsearch; bad; vendor preset: disabled)
   Active: active (exited) since Thu 2017-05-25 10:52:23 GMT; 18min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 16263 ExecStop=/etc/rc.d/init.d/elasticsearch stop (code=exited, status=0/SUCCESS)
  Process: 16270 ExecStart=/etc/rc.d/init.d/elasticsearch start (code=exited, status=0/SUCCESS)
May 25 10:52:23 a-sesklnglsprd1.astrazeneca.net systemd[1]: Starting LSB: This service manages the elasticsearch daemon...
May 25 10:52:23 a-sesklnglsprd1.astrazeneca.net runuser[16281]: pam_unix(runuser:session): session opened for user nagios by (uid=0)
May 25 10:52:23 a-sesklnglsprd1.astrazeneca.net runuser[16281]: pam_unix(runuser:session): session closed for user nagios
May 25 10:52:23 a-sesklnglsprd1.astrazeneca.net elasticsearch[16270]: Starting elasticsearch: /bin/java: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
May 25 10:52:23 a-sesklnglsprd1.astrazeneca.net elasticsearch[16270]: [  OK  ]
May 25 10:52:23 a-sesklnglsprd1.astrazeneca.net systemd[1]: Started LSB: This service manages the elasticsearch daemon.
[root@a-sesklnglsprd1 app]# service logstash status
Logstash Daemon● logstash.service - LSB: Logstash
   Loaded: loaded (/etc/rc.d/init.d/logstash; bad; vendor preset: disabled)
   Active: active (running) since Thu 2017-05-25 10:51:22 GMT; 20min ago
  Process: 15581 ExecStop=/etc/rc.d/init.d/logstash stop (code=exited, status=0/SUCCESS)
  Process: 15595 ExecStart=/etc/rc.d/init.d/logstash start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/logstash.service
           ├─15606 runuser -s /bin/sh -c exec /usr/local/nagioslogserver/logstash/bin/logstash agent -f /usr/local/nagioslogserver/logstash/etc/conf.d -l /var/log/logstash/logstash.log  -w 4 root
           └─15608 /bin/java -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -Djava.awt.headless=true -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp -Xmx500m -Xss20...
May 25 10:51:29 a-sesklnglsprd1.astrazeneca.net logstash[15595]: May 25, 2017 10:51:29 AM org.elasticsearch.plugins.PluginsService <init>
May 25 10:51:29 a-sesklnglsprd1.astrazeneca.net logstash[15595]: INFO: [Typhoid] loaded [], sites []
May 25 10:51:30 a-sesklnglsprd1.astrazeneca.net logstash[15595]: May 25, 2017 10:51:30 AM org.elasticsearch.plugins.PluginsService <init>
May 25 10:51:30 a-sesklnglsprd1.astrazeneca.net logstash[15595]: INFO: [Protector] loaded [], sites []
May 25 10:51:30 a-sesklnglsprd1.astrazeneca.net logstash[15595]: INFO: [Maria Hill] loaded [], sites []
May 25 10:51:30 a-sesklnglsprd1.astrazeneca.net logstash[15595]: INFO: [Access] loaded [], sites []
May 25 10:51:30 a-sesklnglsprd1.astrazeneca.net logstash[15595]: INFO: [Zip-Zap] loaded [], sites []
[root@a-sesklnglsprd1 app]# df -kh
Filesystem                      Size  Used Avail Use% Mounted on
/dev/mapper/vgrp00-Root         8.0G  1.9G  6.2G  23% /
devtmpfs                        7.9G     0  7.9G   0% /dev
tmpfs                           7.9G     0  7.9G   0% /dev/shm
tmpfs                           7.9G  105M  7.8G   2% /run
tmpfs                           7.9G     0  7.9G   0% /sys/fs/cgroup
/dev/mapper/vgrp00-Usr          4.0G  2.5G  1.6G  62% /usr
/dev/sda1                       509M  236M  274M  47% /boot
/dev/mapper/vg_app-lv_app       500G   33M  500G   1% /app
/dev/mapper/vgrp00-Var          6.0G  2.7G  3.4G  45% /var
/dev/mapper/vgrp00-VarLog       7.0G  4.1G  3.0G  58% /var/log
/dev/mapper/vgrp00-VarLogAudit 1014M   58M  957M   6% /var/log/audit
/dev/mapper/vgrp00-home         2.0G   37M  2.0G   2% /home
/dev/mapper/vgrp00-Tmp          2.0G   33M  2.0G   2% /tmp
tmpfs                           1.6G     0  1.6G   0% /run/user/22605
tmpfs                           1.6G     0  1.6G   0% /run/user/22606
tmpfs                           1.6G     0  1.6G   0% /run/user/22036
I have rebooted a multiple times but no luck. Firewall is off
[root@a-sesklnglsprd1 app]# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
[root@a-sesklnglsprd1 app]# curl 'localhost:9200/_cluster/health?level=indices&pretty'
curl: (7) Failed connect to localhost:9200; Connection refused
Re: New Install - Waiting for database startup
Post by dwhitfield »
What's the output of ls /usr/local/nagioslogserver/elasticsearch/plugins/knapsack/?
It's hard to say at this point, but you might want to take a look at https://support.nagios.com/forum/viewto ... 37&t=33804 since we are nearing the end of our day.
anish
Post by anish »
dwhitfield wrote:What's the output of ls /usr/local/nagioslogserver/elasticsearch/plugins/knapsack/?
If you check my post, I did say that I looked at the topic you posted.
This is a new install and not an upgrade.
[root@a-sesklnglsprd1 ~]# ls /usr/local/nagioslogserver/elasticsearch/plugins/knapsack/
elasticsearch-knapsack-1.5.2.0.jar
md5sum is correct
[root@a-sesklnglsprd1 ~]# md5sum /usr/local/nagioslogserver/elasticsearch/plugins/knapsack/elasticsearch-knapsack-1.5.2.0.jar
8df53a4d45b913af0367c08b863e28b8  /usr/local/nagioslogserver/elasticsearch/plugins/knapsack/elasticsearch-knapsack-1.5.2.0.jar
[root@a-sesklnglsprd1 ~]# cat /etc/sysconfig/elasticsearch
# Directory where the Elasticsearch binary distribution resides
APP_DIR="/usr/local/nagioslogserver"
ES_HOME="$APP_DIR/elasticsearch"
# Heap Size (defaults to 256m min, 1g max)
# Nagios Log Server Default to 0.5 physical Memory
ES_HEAP_SIZE=$(expr $(free -m|awk '/^Mem:/{print $2}') / 2 )m
# Heap new generation
#ES_HEAP_NEWSIZE=
# max direct memory
#ES_DIRECT_SIZE=
# Additional Java OPTS
#ES_JAVA_OPTS=
# Maximum number of open files
MAX_OPEN_FILES=65535
# Maximum amount of locked memory
MAX_LOCKED_MEMORY=unlimited
# Maximum number of VMA (Virtual Memory Areas) a process can own
MAX_MAP_COUNT=262144
# Elasticsearch log directory
LOG_DIR=/var/log/elasticsearch
# Elasticsearch data directory
DATA_DIR="$ES_HOME/data"
# Elasticsearch work directory
WORK_DIR="$APP_DIR/tmp/elasticsearch"
# Elasticsearch conf directory
CONF_DIR="$ES_HOME/config"
# Elasticsearch configuration file (elasticsearch.yml)
CONF_FILE="$ES_HOME/config/elasticsearch.yml"
# User to run as, change this to a specific elasticsearch user if possible
# Also make sure, this user can write into the log directories in case you change them
# This setting only works for the init script, but has to be configured separately for systemd startup
ES_USER=nagios
ES_GROUP=nagios
# Configure restart on package upgrade (true, every other setting will lead to not restarting)
#RESTART_ON_UPGRADE=true
if [ "x$1" == "xstart" -o "x$1" == "xrestart" -o "x$1" == "xreload" -o "x$1" == "xforce-reload" ];then
        GET_ES_CONFIG_MESSAGE="$( php $APP_DIR/scripts/get_es_config.php )"
        GET_ES_CONFIG_RETURN=$?
        if [ "$GET_ES_CONFIG_RETURN" != "0" ]; then
                echo $GET_ES_CONFIG_MESSAGE
                exit 1
        else
                ES_JAVA_OPTS="$GET_ES_CONFIG_MESSAGE"
        fi
fi
You have new mail in /var/spool/mail/root
From this error when starting the elasticsearch service
Looks like the Java openjdk package is missing from the system.
Try running the following yum command to install it and see if the service starts for you.
yum install java-1.8.0-openjdk -y
Post back the results.
