Waiting for configuration verification............................................................
This is were it sits, it is like the energizer bunny, it just keeps going and going.
I tried to roll back to the previous config, it does the same thing.
Ideas?
Configuration not being applied
benningtonr
Re: Configuration not being applied
well it finally took. I tried adding the monitoring service I wanted and it says it failed
Configurations failed to write to file.
yet under configuration snapshots it is OK
2017-05-25 10:27:19 Config Ok 1495722439.tar.gz
And I do not see my new host, or service listed, even though it is active.
- Former Nagios Staff
I see that it does eventually complete, but I still think https://support.nagios.com/kb/article.php?id=34 may be of use.
After that, what's the output of the following?
# df -i
# df -h
It's possible you are out of space.
Please run through https://assets.nagios.com/downloads/nag ... tabase.pdf and report any errors. If you stop at any point, please know at which point you stop.
If the repair script and other instructions in the document do not work, please continue.
Regarding the instructions below, if you do not have killall, you can install it via the following command:
# yum install psmisc
If psmisc is not in your repos, then instead you can check to make sure nagios is not running with
# ps -aef | grep nagios
If that document does not resolve your issue, please run the following commands in order and report any errors. You ***must*** use mariadb instead of mysqld in the commands below, ***if*** you have mariadb.
# service nagios stop
# service ndo2db stop
# service mysqld stop
# service crond stop
# service httpd stop
# killall -9 nagios
# killall -9 ndo2db
# rm -f /usr/local/nagios/var/ndo.sock
# rm -f /usr/local/nagios/var/ndo2db.lock
# service ndo2db start
# service nagios start
# service mysqld start
# service crond start
# service httpd start
If those do not resolve your issue, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
# df -i
# df -h
# killall -9 nagios
# killall -9 ndo2db
benningtonr
All is well, i shut down the VM and added 5gig ram and two more cores to the system procesor.
I also only added the bandwith service to the switch, I have unlimited services, but that worked.
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
benningtonr
yes, please do thanks
