my nsclient.ini i have:
check_updates=cmd /c echo scripts\Check-Updates.ps1 $ARG1$; exit $LastExitCode | powershell.exe -command -Code: Select all
./check_nrpe -H g1vpskparc01 -t 120 -c check_updates 33Code: Select all
'GracePeriod'. Cannot convert value "$" to type "System.Int32". Error: "Input
string was not in a correct format."
At C:\Program Files\NSClient++\scripts\Check-Updates.ps1:92 char:33
+ $UpdateTime = Check-LastUpdate $GracePeriod
+ CategoryInfo : InvalidData: (:) [Check-LastUpdate], ParameterBi
ndingArgumentTransformationException
+ FullyQualifiedErrorId : ParameterArgumentTransformationError,Check-LastU
pdate
param($warn)
$output1 = $warn | out-file c:\scripts\grace.txt
and instead of the number 33, it is passing and single $ sign
I have retyped the ini line many times in thinking that maybe a hidden character had gotten there some how..... and no luck
Can you see what boneheaded thing i did??
