Error when Installing NagiosXI manually in Virtual machine
yayan
Post by yayan »
Dear All,
I try install NagiosXI in My VMWare, by following below procedure https://assets.nagios.com/downloads/nag ... -Linux.pdf , but in the end I got below error, also I'm attach the install.log for your refference, please let me know what the mistake?
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
root@yy-virtual-machine:/tmp/nagiosxi# ll
Regards,
Yayan
Re: Error when Installing NagiosXI manually in Virtual machi
Post by mcapra »
Officially, CentOS and RHEL are the supported flavors of Linux. Per this article:
https://support.nagios.com/kb/article.php?id=12
I would recommend using CentOS or RHEL as Ubuntu is not supported based on the above article.
Thanks for the post, @mcapra! OP, let us know if you have further questions.
