no log handling during upgrade
benhank
Post by benhank »
Hey all. During my upgrade of my nagios system I get this message
No log handling enabled - turning on stderr logging
/usr/local/nagioslogserver/mibs/NAGIOS-ROOT-MIB.txt: No such file or directory
/usr/local/nagioslogserver/mibs/NAGIOS-NOTIFY-MIB.txt: No such file or directory
What does it mean and how to I fix it?
Proudly running:
Nagios Network Analyser
Nagios Fusion
avandemore
Re: no log handling during upgrade
Post by avandemore »
Can you provide the full upgrade.log?
The first message can be ignored, but the trailing 2 are not normal.
Previous Nagios employee
benhank
Post by benhank »
to quote meeseeks: CAN DO!
upgrade.log
Proudly running:
Nagios Fusion
avandemore
From XI > Admin > Manage Components, what version is your SNMP Trap Sender?
Can you send me the file /var/log/httpd/error_log as well?
Just checking in since we have not heard from you in a while. Did @avandemore's post clear things up or has the issue otherwise been resolved?
