i need to plot graph using data Xi>>report>>State History.
Target is to use the "information" to plot values( if possible) or use defined threshold as measures and plot graph.
Suggest how to achieve it?
-A
Nagiosxi Reporting
avandemore
Re: Nagiosxi Reporting
You could download the data as CSV and use something that can generate a plot graph to read it.
Previous Nagios employee
Any better way? which can be used to display graph on nagios portal or central web page?
avandemore
You could write a custom component or something, but I don't know of anything else.
Just checking in since we have not heard from you in a while. Did @avandemore's post clear things up or has the issue otherwise been resolved?
