Best approach to address Leap second on Open Systems
Gpeterkin
Post by Gpeterkin »
UPDATED
Need to know what is the approach for addressing leap second on Open Systems.
The latest Nagios Plugin was recommended as a fix, but due to the work involved, we are considering a Nagios suite upgrade instead.
What do you have available as a Nagios suite upgrade?
Garvin Peterkin
avandemore
Re: Best approach to address Leap second on Open Systems
Post by avandemore »
I'm not exactly sure about what you are asking but the recommended way to upgrade Nagios XI is here:
https://assets.nagios.com/downloads/nag ... nstall.pdf
Does this answer your question?
Previous Nagios employee
Just checking in since we have not heard from you in a while. Did @avandemore's post clear things up or has the issue otherwise been resolved?
