Hi All ,
i have installed the nagiosxi server, when i add a route or switch device to nagios , the interface status is ok but the bandwidth status show "/var/lib/mrtg/xxxxxx.rrd does not exist."
i have installed mrtg in our nagios server .
any idea for me to fix it?
Thanks.
/var/lib/mrtg/.rrd does not exist.
avandemore
Re: /var/lib/mrtg/.rrd does not exist.
Previous Nagios employee
Can you run the following commands, and show the output?
What is the version of the Nagios XI server that you are currently using?
ls -l /var/lib/mrtg
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgBe sure to check out our Knowledgebase for helpful articles and solutions!
i have tried run above command no error show out.lmiltchev wrote:Can you run the following commands, and show the output?
What is the version of the Nagios XI server that you are currently using?Code: Select all
ls -l /var/lib/mrtg LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_200000000.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_2.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_3.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_400000000.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_400000001.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_4.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_5.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_6.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.1.2_7.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_12.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_13.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_14.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_15.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_16.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_17.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_18.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_19.rrd
-rw-r--r-- 1 apache apache 105312 Jun 2 11:05 192.168.21.254_20.rrd
-rw-r--r-- 1 root root 2151 Jun 7 11:25 mrtg.ok
avandemore
XI > Admin > System Profile > Download Profile
Please include the zip file in your response. You can PM to myself or other support personnel.
Just checking in since we have not heard from you in a while. Did @avandemore's post clear things up or has the issue otherwise been resolved?
