Limit the number of simultaneous login to XI web console
vinish098
Post by vinish098 »
Can we set the number of simultaneous login of Nagios XI web console to 10?
Kindly let me know how can I achieve this.
avandemore
Re: Limit the number of simultaneous login to XI web console
Post by avandemore »
There is nothing that would natively do this, and if you tried to use something like an Apache configuration or firewall connection to accomplish it then you would need to account for all the backend logins.
What is the real problem you are trying to solve?
Previous Nagios employee
Just checking in since we have not heard from you in a while. Did @avandemore's post clear things up or has the issue otherwise been resolved?
vinish098
Post by vinish098 »
Hi avandemore,
I am not facing any problem. Just we want to provide login to 5 users only.
Use case: If already five Nagios Xi sessions are open and sixth person trying to login, He should not able to do even he knows the password.
vinish098 wrote:Hi avandemore,
Sorry, this is not possible in Nagios XI.
