Centos/Linux Plugins Missing
rcaparros
Post by rcaparros »
Folks,
Loaded nagios-plugins-release 2.2.1 and noticed the check_cpu_stats and check_init_service is missing in /libexec.
NRPE ver:
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
NRPE v3.1.1
NAGIOS XI version 5.4.3
OS:
CentOS Linux release 7.3.1611 (Core)
TIA,
Ray
avandemore
Re: Centos/Linux Plugins Missing
Post by avandemore »
If you install the Nagios plugins, you'll have them:
https://nagios-plugins.org/
This will update the plugins to the latest versions which will be newer than the ones distributed with XI. Any future upgrade of XI will revert the standard plugins back to stock versions.
Previous Nagios employee
rcaparros
Post by rcaparros »
Thank you!
Is your issue resolved now? Can we close this topic?
