Flapping state from nsclient++ ws2012
pokrak
Post by pokrak »
Hi.
Nagios flaps with warnings on Windows 2012. Once it shows the correct data, then after a while it gets the message from the same plugin "No data was recived from host" Data is collected using check_nt
Thank`s for help
avandemore
Re: Flapping state from nsclient++ ws2012
Post by avandemore »
Here is some information on flapping, including settings:
https://assets.nagios.com/downloads/nag ... pping.html
What is the full output from XI > Configure > CCM > Services > yourservice > Run Check Command
Previous Nagios employee
pokrak
Post by pokrak »
All services on windows host are ok it`s a new machine
pokrak
Post by pokrak »
I was generate new nsclient.ini it seems be ok
Are you still having issues or we can close this topic, and mark it as "resolved"?
