I have 2 Nagios Log Server nodes in cluster, receiving log data of approximately 250 servers. However, for no reason the application gets down. The only entries I found looking at the Logstash and Elasticsearch logs are below:
###Errors on Logstash
{:timestamp=>"2017-06-12T13:26:59.967000-0300", :message=>"Received an event that has a different character encoding than you configured.", :text=>"{\\\"EventReceivedTime\\\":\\\"2017-06-09 21:02:11\\\",\\\"SourceModuleName\\\":\\\"file1\\\",\\\"SourceModuleType\\\":\\\"im_file\\\",\\\"message\\\":\\\"2017-06-09 21:02:10 ERROR couldn't connect to tcp socket on AAA.BBB.CCC.DDD:3515; Nenhuma conex\\xE3o p\\xF4de ser feita porque a m\\xE1quina de destino as recusou ativamente. \\\"}\\r", :expected_charset=>"UTF-8", :level=>:warn}
{:timestamp=>"2017-06-12T13:27:01.691000-0300", :message=>"retrying failed action with response code: 429", :level=>:warn}
{:timestamp=>"2017-06-12T13:27:01.692000-0300", :message=>"retrying failed action with response code: 429", :level=>:warn}
###After restart Logstash and Elasticsearch
{:timestamp=>"2017-06-12T13:30:34.964000-0300", :message=>"retrying failed action with response code: 429", :level=>:warn}
{:timestamp=>"2017-06-12T13:55:04.505000-0300", :message=>"Failed to install template: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-06-12T13:55:04.768000-0300", :message=>"Failed to install template: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-06-12T13:55:04.792000-0300", :message=>"Failed to install template: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-06-12T13:55:04.950000-0300", :message=>"Failed to install template: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-06-12T13:55:04.954000-0300", :message=>"Failed to install template: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-06-12T13:55:06.625000-0300", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-06-12T13:55:06.628000-0300", :message=>"Failed to flush outgoing items", :outgoing_count=>219, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:606)", "RUBY.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "RUBY.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "RUBY.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "Stud::Buffer.buffer_receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:159)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::ElasticSearch.receive(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:455)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "LogStash::Outputs::Base.handle(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:88)", "RUBY.worker_setup(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-core-1.5.1-java/lib/logstash/outputs/base.rb:79)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
###After open the sockets for receive the logs
{:timestamp=>"2017-06-12T13:56:28.716000-0300", :message=>"Got error to send bulk of actions: None of the configured nodes are available: []", :level=>:error}
{:timestamp=>"2017-06-12T13:56:28.716000-0300", :message=>"Failed to flush outgoing items", :outgoing_count=>243, :exception=>org.elasticsearch.client.transport.NoNodeAvailableException: None of the configured nodes are available: [], :backtrace=>["org.elasticsearch.client.transport.TransportClientNodesService.ensureNodesAreAvailable(org/elasticsearch/client/transport/TransportClientNodesService.java:279)", "org.elasticsearch.client.transport.TransportClientNodesService.execute(org/elasticsearch/client/transport/TransportClientNodesService.java:198)", "org.elasticsearch.client.transport.support.InternalTransportClient.execute(org/elasticsearch/client/transport/support/InternalTransportClient.java:106)", "org.elasticsearch.client.support.AbstractClient.bulk(org/elasticsearch/client/support/AbstractClient.java:163)", "org.elasticsearch.client.transport.TransportClient.bulk(org/elasticsearch/client/transport/TransportClient.java:356)", "org.elasticsearch.action.bulk.BulkRequestBuilder.doExecute(org/elasticsearch/action/bulk/BulkRequestBuilder.java:164)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:91)", "org.elasticsearch.action.ActionRequestBuilder.execute(org/elasticsearch/action/ActionRequestBuilder.java:65)", "java.lang.reflect.Method.invoke(java/lang/reflect/Method.java:606)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::Elasticsearch::Protocols::NodeClient.bulk(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch/protocol.rb:224)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:466)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.submit(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:465)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:490)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "LogStash::Outputs::ElasticSearch.flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-elasticsearch-0.2.8-java/lib/logstash/outputs/elasticsearch.rb:489)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:219)", "org.jruby.RubyHash.each(org/jruby/RubyHash.java:1341)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:216)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "Stud::Buffer.buffer_flush(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:193)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:112)", "org.jruby.RubyKernel.loop(org/jruby/RubyKernel.java:1511)", "RUBY.buffer_initialize(/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/stud-0.0.19/lib/stud/buffer.rb:110)", "java.lang.Thread.run(java/lang/Thread.java:745)"], :level=>:warn}
Is there any other place in the tool where I can find details of what is happening to the environment? Can this unexpected fault behavior be corrected by performing some kind of tunning in the environment?
Thank you for your help!
