W.W.
Posts: 17 Joined: Wed Apr 05, 2017 3:18 am
Post
by W.W. » Tue Jun 13, 2017 9:09 am
Dear all,
When I reboot nagios Core 4.1, I get this error
No lock file found in /usr/local/nagios/var/nagios.lock
nagios.lock does not exist and nagios -v don't return error.
So, I create it the manually and now when I do
service nagios status
I have the below output
Any help would be appreciated
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Tue Jun 13, 2017 11:18 am
How did you install Nagios? What tutorial/guide did you follow? What is the OS/architecture of the system you installed Nagios on? Do you have SELinux running on this box? What is the output of the following command?
Be sure to check out our
Knowledgebase for helpful articles and solutions!
W.W.
Post
by W.W. » Wed Jun 14, 2017 2:16 am
Thank you for the reply.
I didn't make the installation, I don't know which tuto was use but it's a FAN installation on CentOS 6.9. SELinux is disabled
/etc/init.d/nagios configtest
[root@- var]# /etc/init.d/nagios configtest
Nagios Core 4.1.0rc1
Last Modified: 02-18-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 878 services.
Checked 383 hosts.
Checked 14 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 37 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 383 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Object precache file created:
/usr/local/nagios/var/objects.precache
W.W.
Post
by W.W. » Wed Jun 14, 2017 4:12 am
My problem was solved by switching off ndo2db, mysqld and httpd.
Can we close this post
