Hello, i need you help.
I have Centos 7 and using apache 2.4.23 which i сompiled from sources. If i do yum install httpd than i have too old version 2.4.10, but i need version > 2.4.10 for some reason. I used this documentation for install - https://assets.nagios.com/downloads/nag ... entos7.pdf.
And with apache 2.4.23 i got error 404. But if i remove version 2.4.23 and install again with documentation + yum install htttpd . Than i haven't got problem.
What the problem?
Thanks!
Nagios with apache 2.4.23
Re: Nagios with apache 2.4.23
There is a difference between building a shed by hand, and buying a kit from the hardware store. Think of yum as being like a hardware store; They sell pre-built, manufactured stuff (like the httpd package) as well as raw materials to build whatever you like (like the gcc package).But if i remove version 2.4.23 and install again with documentation + yum install htttpd . Than i haven't got problem
That documentation was written against whatever version of Apache is distributed via the yum package httpd. If that's not the version of Apache you want to use, you'll have to figure out how to change the Apache configurations that Nagios Core automatically creates.
Typically, the make install-webconf step is what creates those Apache configurations. It may be that Nagios Core is attempting to place the Apache configurations in the incorrect path. If you could share the contents of your Apache configuration paths, as well as the contents of those configuration files, that'd be a good start.
- Former Nagios Staff
You might also try https://support.nagios.com/kb/article.php?id=96#CentOS, which are more current. Notice the difference in the Nagios Core version #.
