Hi all, i'm not understand, why nagios event handler not worked. =-(
Nagios server log file:
nagios:~ # tail -f /var/opt/nagios/local/nagios.log | perl -pe 's/(\d+)/localtime($1)/e' | grep myhostname.*
[Thu Jun 15 12:35:44 2017] SERVICE ALERT: myhostname;NTP::Service availability;CRITICAL;SOFT;1;NTPD service inactive\n
[Thu Jun 15 12:35:44 2017] SERVICE EVENT HANDLER: myhostname;NTP::Service availability;CRITICAL;SOFT;1;restart-ntpd
[Thu Jun 15 12:36:48 2017] SERVICE ALERT: myhostname;NTP::Service availability;CRITICAL;SOFT;2;NTPD service inactive\n
[Thu Jun 15 12:36:48 2017] SERVICE EVENT HANDLER: myhostname;NTP::Service availability;CRITICAL;SOFT;2;restart-ntpd
[Thu Jun 15 12:37:48 2017] SERVICE ALERT: myhostname;NTP::Service availability;CRITICAL;SOFT;3;NTPD service inactive\n
[Thu Jun 15 12:37:48 2017] SERVICE EVENT HANDLER: myhostname;NTP::Service availability;CRITICAL;SOFT;3;restart-ntpd
[Thu Jun 15 12:38:51 2017] SERVICE ALERT: myhostname;NTP::Service availability;CRITICAL;HARD;4;NTPD service inactive\n
[Thu Jun 15 12:38:51 2017] SERVICE EVENT HANDLER: myhostname;NTP::Service availability;CRITICAL;HARD;4;restart-ntpd
command.cfg:
command_name restart-ntpd
command_line $USER$/check_nrpe -H $HOSTADDRESS$ -c restart-ntpd -a $SERVICESTATE$ $SERVICESTATETYPE$ $SERVICEATTEMPT$
local command file (/etc/nrpe.d):
command[restart-ntpd]=/usr/lib64/nagios/plugins/eventhandlers/restart-ntpd $ARG1$ $ARG2$ $ARG3$
event handler script:
rights:
[root@myhostname sergey]# ll /usr/lib64/nagios/plugins/eventhandlers/restart-ntpd
-rwxrwxr-x 1 root root 525 Jun 15 12:27 /usr/lib64/nagios/plugins/eventhandlers/restart-ntpd
script:
#!/bin/sh
case "$1" in
OK)
WARNING)
UNKNOWN)
CRITICAL)
case "$2" in
SOFT)
case "$3" in
1)
2)
3)
echo -n "Restarting NTP service (3rd soft critical state)..."
/usr/bin/sudo /bin/systemctl restart ntpd > /dev/null
esac
HARD)
echo -n "Restarting NTP service..."
esac
esac
exit 0
User nrpe added in sudoers, and if i do command - "/opt/nagios/libexec/check_nrpe -H myhostname -c restart-ntpd -a CRITICAL SOFT 3" from nagios server, all works fine, service on remote host was restarted.
Please help, i don't know where problem...
Don't work event handler, PLEASE HELP!
Re: Don't work event handler, PLEASE HELP!
Can you add this to the top of your /usr/lib64/nagios/plugins/eventhandlers/restart-ntpd script on the remote host, simulate the failure and post the /tmp/event file from the remote server?
#!/bin/sh
echo $1 >>/tmp/event
echo $2 >>/tmp/event
echo $3 >>/tmp/eventBe sure to check out our Knowledgebase for helpful articles and solutions!
Hello tgriep,
Thanks for you reply! Yesterday i solved problem. The problem has been in the same command name in service configuration that in the local nrpe configuration on remote host, after i change name in service configuration on nagios server (service.cfg and commands.cfg), event handler has earned.
command.cfg:
in service.cfg for check of ntp service, i changed event_handler parameter value to restart-ntp-host, and change command_name value in commands.cfg on the same.
Thank you!
Best regards,
Sergey Kuzmitskiy
command.cfg:
Thank you!
Best regards,
Sergey Kuzmitskiy
Glad you figured it out. I'll close and lock the post for you but if you have a new issue in the future, feel free to open a new post.
