MongoDB Services Incorrect Username/Password
sarfarosh
Post by sarfarosh »
Hi Team,
We configured the mongodb server but we are facing the issue of incorrect username/password. I am using username=testuser and password=testuser. The plugin is check_mongodb.py
Re: MongoDB Services Incorrect Username/Password
What is the version of the Nagios XI and the MongoDB Server wizard that you are currently using? Can you show us an example of a check that you are running from the command line, along with the output of it?
Example:
[root@main-nagios-xi nagiosxi]# /usr/local/nagios/libexec/check_mongodb.py -H x.x.x.x -A collections -P 27017 -W 300 -C 500 -u test -p test -D --all-databases
OK - Number of collections: 4 |collections=4;300.0;500.0
Do you see any relevant errors in the apache error log, when you run the check?
tail -100 /var/log/httpd/error_log
sarfarosh
Post by sarfarosh »
Hi lmiltchev,
Please find the asked details with screenshot in attachment.
sarfarosh
Post by sarfarosh »
Hi lmiltchev,
Nagios xi version is 5.4.5 and MongoDB server version is 3.2
Can you verify that the Mongo database has authentication enabled and that the user account has sufficient permissions that are outlined on page 1 of the following document?
