Nagios not loading bash_profile
hales8181
Post by hales8181 »
I am trying to get an AWS plug-in working (https://github.com/level23/nagios-cloudwatch-metrics)
I have installed awscli as the nagios user, and can run it on the command line (although had to edit the .bash_profile to add: export PATH=~/.local/bin:$PATH
I can run the nagios-cloudwatch-metrics from the command line with no issue, however when I try to run it from within nagios it can't seem to find the aws executable.
I'm presuming this is because nagios isn't loading the bash_profile - is there somewhere in a nagios config where I export PATH to get it to be able to find it?
Re: Nagios not loading bash_profile
You could edit he script ans put the full in the command and that should work as well for you.
Add the directory to the aws command to this line and see if it works.
COMMAND="aws cloudwatch get-metric-statistics"
SteveBeauchemin
Post by SteveBeauchemin »
make a symbolic link to the location.
ln -s /real-location/aws /usr/local/bin/aws
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Post by dwhitfield »
Thanks for the assist @SteveBeauchemin!
hales8181
Post by hales8181 »
Thanks, changing the COMMAND in the script to the location works - I'll give the symbolic link a try tomorrow and let you know!
Ok, great, we'll be here tomorrow!
