Nagtrap - LinkUp
blabli
Nagtrap - LinkUp
Post by blabli »
I installed Nagtrap on Nagios and it seems to work fine.
But I have a problem with LinkUp Traps, I get a lot in a very short time for the same event.
Do you have an idea?
(sorry, Google translate)
thanks for your help
Re: Nagtrap - LinkUp
Post by mcapra »
Just chiming in to say that I don't believe Nagtrap is maintained anymore.
Depending on your use case, you might use NSTI instead:
https://github.com/NagiosEnterprises/nsti
Thanks @mcapra for the tip.
It looks like Nagtrap uses snmptt to translate the Traps and the traps are logged in the following file.
/var/log/snmptt/snmptt.log
Take a look at that file for any clues on your issue or the system that sent them to see if they are logged there.
blabli
Post by blabli »
thank you for your quick reply
The snmptt.log file resembles the previous image, it receives on a very short time several LinkUp traps for the same host
The difference it finds in the message: A linkUp trap means that the SNMP entity, acting in an 18
In effect the value changes: 1,2,3,4,5 ...
For other traps no problem but only for LinkUP
Thanks mcapra I will learn about the tool nsti
If you do not need the linkup messages, you can remove them from the /etc/snmp/snmptt.conf file so the snmptt daemon will not translate them anymore.
blabli
Post by blabli »
Yes I think I will delete it, after all it is not necessarily useful
Thank you for your time
Last question about NSTI: Can it integrate on Nagios interfarce like Nagtrap or it necessarily uses a second interface? thank you
NSTI is it's own separate interface.
NSTI is a Nagios addon that makes managing SNMP traps easier. NSTI provide a PHP frontend for the SNMPTT database backend and allows you to filter SNMP results quickly and effectively to get a comprehensive overview of the information you want to see.
You can find more information about it here
https://exchange.nagios.org/directory/A ... I)/details
If you want to receive SNMP Traps in Nagios Core, take a look at this link for instructions.
https://exchange.nagios.org/directory/T ... os/details
blabli
Post by blabli »
Thank you very much for your help and this additional information
The subject can be closed :) :)
I'll be closing this thread now, but feel free to open another if you need anything in the future!
