monitoring and reporting stopped. ndoutils error on console
albertaarts
Hi there. I'm hoping someone can help me out. Recently our Nagiox XI stopped reporting issues and the homepage of the web interface has the following message repeated many times over: SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_programstatus' SQL
- Former Nagios Staff
Re: monitoring and reporting stopped. ndoutils error on cons
You need to run the following:
If that doesn't work, you may need to run the following mysql -u ndoutils -pn@gweb nagios -e 'TRUNCATE TABLE nagios_programstatus'
You may get some other ideas by looking at https://assets.nagios.com/downloads/nag ... tabase.pdf
service mysqld start
echo 'repair table nagios_programstatus use_frm;' | mysql -t -u root -pnagiosxi nagios
service mysqld restartYou may get some other ideas by looking at https://assets.nagios.com/downloads/nag ... tabase.pdf
albertaarts
thanks! that didn't work but that is all good information. i'll get more familiar with database backups and maintenance.
There is a script on the Nagios server that you can use to repair all of the databases on the server.
To use it, login to the server as root and run the following
If it works, it should fix the invalid file format error for you.
./repair_databases.shBe sure to check out our Knowledgebase for helpful articles and solutions!
albertaarts
thank you. it did not fix it but this is good to know.
- tacolover101
look at https://assets.nagios.com/downloads/nag ... tabase.pdf under the 'troubleshooting' section, the second example is the same issue you're facing, so this should help you resolve it.
albertaarts, did you follow the document, referenced by tacolover101? Did this help?
