Hi all,
i'm new to nagios, i installed check_mk monitoring tool with 50 hosts, current performance report shows 495 pages (PDF)
i edited cfg file (/opt/omd/sites/sitename/etc/pnp4nagios/pages) to include CPU, filesystem and memory)
is it possible to reduce number of pages (i would like to remove graphs,for example)
Thanks in advance
Dragan
Nagios pnp4nagios performance report
Re: Nagios pnp4nagios performance report
I will be closing this thread as you have an identical one open here: https://support.nagios.com/forum/viewto ... 9&p=225131
Please do not post the same issue multiple times, especially in different areas of the forum. This only increases the time it takes us to provide support.
