HPUX disk check install question
benhank
Post by benhank »
Hey guys, this is a followup to this post:
https://support.nagios.com/forum/viewtopic.php?f=16&t=43826&p=220823#p220823
JFrickson fixed it, but how do I get and install the fixed plugin? I'm not to familiar with github.
https://github.com/nagios-plugins/nagios-plugins/issues/276
Proudly running:
Nagios Network Analyser
Nagios Fusion
cdienger
Re: HPUX disk check install question
Post by cdienger »
The changes can be found in the maintenance release. You can download it at https://github.com/nagios-plugins/nagio ... tree/maint or going directly to https://github.com/nagios-plugins/nagio ... /maint.zip .
benhank
Post by benhank »
thanks man! you can lock it up
Proudly running:
Nagios Fusion
