Hey,
When I try to apply config I get the following since an upgrade to 5.4.5.
Error: Contact 'opsgenie' has no service notification commands defined!
Error: Contact 'opsgenie' has no host notification commands defined!
This user has commands defined for both host & service.
Any suggestions?
No commands defined for contact.
kevinmjacobsen
Last edited by kevinmjacobsen on Thu Jun 29, 2017 1:09 pm, edited 1 time in total.
kevinmjacobsen
Re: No commands defined for contact.
After a search I did the following to fix the apply config issue:
XI > Configure > Core Config Manager > Config File Management > Delete Files > Write Configs > Verify Files > Restart Nagios Core
