Hi ,
We are currently using nagios xi 5.2.2 , running on RHEL 6.9 server
We wanted to get the report (graph and excel) of memory , CPU utilization of specific servers in mail to be scheduled weekly in nagios.
Please assist
CPU and memory Utilization report via mail
inas.labib
Re: CPU and memory Utilization report via mail
There is not a report in Nagios XI that you can use to get the Memory , CPU utilization, especially in Excel format.
You could get the Graph of the information by using the Metrics Component in XI.
First thing to do is to create a Host Group and add all of the hosts you want to run the report against.
Then go to the Home > Metrics menu, select the Hostgroup and change the settings to what you need and click the Run button.
Then select the Graph Tab, change the Time frame to the last 7 days and you should be able to view the graphs for those hosts.
Then to schedule that page, on the right side of the username there are 3 lines, click that and click on the Clock icon to schedule the page.
Fill in the information and save it and then it will be emailed on that schedule for you.
