Nagios is not using configured retry interval times
neosecurearg
Post by neosecurearg »
We have an issue with Nagios XI, which is not using configured retry interval times as expected.
For example, for check the host nwsrma1, whe have these values configured:
Check interval 4 min
Retry interval 1 min
Max check attempts 3 attempts
But when we check Nagios logs, on /var/log/messages, we see:
Jul 3 16:35:35 possrv1 nagios: HOST ALERT: nwsrma1;DOWN;SOFT;1;CRITICAL - 10.10.10.190: rta nan, lost 100%
Jul 3 16:36:05 possrv1 nagios: HOST ALERT: nwsrma1;DOWN;SOFT;2;CRITICAL - 10.10.10.190: rta nan, lost 100%
Jul 3 16:36:20 possrv1 nagios: HOST ALERT: nwsrma1;DOWN;HARD;3;CRITICAL - 10.10.10.190: rta nan, lost 100%
Jul 3 16:36:20 possrv1 nagios: HOST NOTIFICATION: Alejandro Guida;nwsrma1;DOWN;notify-host-by-syslog;CRITICAL - 10.10.10.190: rta nan, lost 100%
Jul 3 16:36:20 possrv1 nagios: HOST NOTIFICATION: Alejandro Guida;nwsrma1;DOWN;notify-host-by-email;CRITICAL - 10.10.10.190: rta nan, lost 100%
Jul 3 16:36:26 possrv1 nagios: HOST ALERT: nwsrma1;UP;HARD;3;OK - 10.10.10.190: rta 3.030ms, lost 0%
Jul 3 16:36:26 possrv1 nagios: HOST NOTIFICATION: Alejandro Guida;nwsrma1;UP;notify-host-by-syslog;OK - 10.10.10.190: rta 3.030ms, lost 0%
Jul 3 16:36:26 possrv1 nagios: HOST NOTIFICATION: Alejandro Guida;nwsrma1;UP;notify-host-by-email;OK - 10.10.10.190: rta 3.030ms, lost 0%
As you can see, the first check is at 16:35:35, the retry check is at 16:36:05 (30 seconds later), and the last retry check before nwsrma1 is marked DOWN in HARD STATE is at 16:36:20 (15 seconds later).
Can you explain to us what is happening, or what files/logs do you need to review this issue? Atthached profile.zip of our system.
Thanks in advance.
Regards.
Linux Distribution: CentOS release 6.5, 64 bits
Manual Installed Nagios XI, version 5.4.5
eloyd
Cool Title Here
Re: Nagios is not using configured retry interval times
Post by eloyd »
Host checks are done as needed unless forced to be done on schedule. It sometimes means that your timing is not what you think it is, if a service that fails, Nagios checks the host to see if the host is down (thus, explaining why the service failed). Examine https://assets.nagios.com/downloads/nag ... hecks.html for more details, but I think you're seeing normal behavior
Thanks for the assist, @eloyd!
