hi
We have latest version of nagios core but nagios display "plugin timeout" error instead of "packet loss" error in "Service Problems".
What is your approach?
thanks
nagios 4.3.2 show "plugin timeout" instead of "packet loss"
asiansuntrading
Re: nagios 4.3.2 show "plugin timeout" instead of "packet lo
Plugin timeout means that the plugin did not return a result in the timeout window allowed by Nagios (default is 60 seconds for a service). It is possible that your plugin has its own timeout that's longer than this, thus Nagios stops listening after 60 seconds and displyas "plugin timeout" because it gets no response from the plugin within 60 seconds, even though the plugin would eventually return its own error message.
Thanks for the assist, @eloyd!
asiansuntrading
hi
How can I fix it?
How can I fix it?
Can you post how the command is defined so we can verify that the settings are correct?
If you are using the check_ping plugin for that service, it will not return a packet loss message but the check_icmp plugin will if it cannot connect to the remote system.
Change your service to use the check_icmp instead.
asiansuntrading
hi
Yes, we use the check_ping command but before than we upgrade our nagios core to 4.3.2, this plugin returns us packet loss 100% items...
$USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5Re: nagios 4.3.2 show "plugin timeout" instead of "packet lo
There are a few things you can do.
1. Change to the check_icmp plugin.
2. Downgrade the check_ping plugin to an older version which worked the way you want.
3. Fill in a bug report at the link below to get the check_ping bug fixed.
https://github.com/nagios-plugins/nagios-plugins/issues
asiansuntrading
Your welcome.
