check_nrep 3.2.0 how eliminate used% perfdata
emi65
Post by emi65 »
Here my comand
check_nrpe -H 10.205.143.15 -c CheckDriveSize -a ShowAll=long Drive=S:\\archivegroups01\\archive2
WARNING warning(S:\archivegroups01\archive2: Total: 2.881TB - Used: 2.51TB (88%) - Free: 379.87GB (12%))|'S:\archivegroups01\archive2 used'=2.50976TB;2.30458;2.59266;0;2.88073 'S:\archivegroups01\archive2 used %'=87%;80;90;0;100
from the output I like to eliminate the "used %'=87%;80;90;0;100"
Is the an option to delete this perfdata from comand output ?
Emilio
Re: check_nrep 3.2.0 how eliminate used% perfdata
Post by mcapra »
This actually has less to do with check_nrpe and more to do with the CheckDriveSize command for NSClient++.
You can change performance data related items, which is everything that follows the | character in Nagios output, by leveraging the perf-syntax argument. Specifically, by manipulating where used_pct is located (or not located) in your performance data syntax.
See the links provided for more information about each item.
Thanks for the assist, @mcapra!
