problem with nrpe and ubuntu
majed
Post by majed »
Health be upon you,
today I installed an ubuntu with nrpe and it worked because I enabled the root user.
On 3 previous ubuntu's, it is not working because the root is disabled.
here is the error:
cd /usr/lib/nagios/plugins/
@NE8:/usr/lib/nagios/plugins$ sudo -s -u nagios ./check_nrpe -H 127.0.0.1 -c check_disk
NRPE: Unable to read output
I researched the error and it is narrowed to:
either the path nrpe.cfg is wrong or there is a permission problem.
according to
https://serverfault.com/questions/32323 ... ut-but-why
nagios ALL=(ALL) NOPASSWD:/usr/lib/nagios/plugins/
must be added to the sudoers file.
I am reluctant to do that as in the past i played with the sudoers file and it stopped being accessed! I had to use the ubuntu cd to edit it and this is dangerous in a production environment.
do you confirm that this is the problem?
config of /etc/nagios/nrpe.cfg
allowed_hosts=127.0.0.1, 10.10.10.12
command[check_users]=sudo /usr/lib/nagios/plugins/check_users -w 5 -c 10
command[check_load]=sudo /usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
command[check_disk]=sudo /usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/sda3
command[check_zombie_procs]=sudo /usr/lib/nagios/plugins/check_procs -w 5 -c 10 -s Z
command[check_total_procs]=sudo /usr/lib/nagios/plugins/check_procs -w 150 -c 200
command[check_swap]=sudo /usr/lib/nagios/plugins/check_swap -w 20 -c 10
command[check_mem]=sudo /usr/lib/nagios/plugins/check_mem.pl -u -w 80 -c 90
command[check_cpu]=sudo /usr/lib/nagios/plugins/check_cpu.sh -i 5 -w 80 -c 90
ls -l /etc/nagios
total 20
-rwxr-xr-x 1 nagios nagios 8240 июл  5 12:56 nrpe.cfg
drwxr-xr-x 2 nagios nagios 4096 май  8 19:01 nrpe.d
-rwxr-xr-x 1 nagios nagios  117 май  8 19:00 nrpe_local.cfg
ls -l /usr/lib/nagios/
total 4
drwxr-xr-x 2 nagios nagios 4096 июл  5 12:24 plugins
 sudo ps cax | grep nrpe
12473 ?        Ss     0:00 nrpe
Seek and you shall find, knock and it shall be opened, cry and you shall find comfort
Re: problem with nrpe and ubuntu
Can you verify the NRPE version and installation method? If it was not compiled from source obtained on our GitHub then it might be an older version with known/unknown bugs depending on the packager/maintainer.
majed
Post by majed »
here is how it was installed:
sudo apt-get install openssl nagios-nrpe-server nagios-plugins nagios-plugins-basic nagios-plugins-standard
NRPE v2.15
In /etc/nagios/nrpe.cfg you have all the checks prefaced with sudo
you shouldn't need this with most, but if you do have it in there you would need to add the sudo permissions to your sudoers file.
To start with, I would remove sudo from the commands in , restart nrpe and try to make the connection from 10.10.10.12
sudo -s -u nagios ./check_nrpe -H IP_OF_MACHINE_WITH_NRPE -c check_disk
majed
Post by majed »
ok i removed sudo:
command[check_users]=/usr/lib/nagios/plugins/check_users -w 5 -c 10
command[check_load]=/usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
command[check_disk]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/sda1
command[check_zombie_procs]=/usr/lib/nagios/plugins/check_procs -w 5 -c 10 -s Z
command[check_total_procs]=/usr/lib/nagios/plugins/check_procs -w 150 -c 200
command[check_swap]=/usr/lib/nagios/plugins/check_swap -w 20 -c 10
command[check_mem]=/usr/lib/nagios/plugins/check_mem.pl -u -w 80 -c 90
command[check_cpu]=/usr/lib/nagios/plugins/check_cpu.sh -i 5 -w 80 -c 90
restarted nrpe..
sysadmin@NS5:/usr/lib/nagios/plugins$ sudo -s -u nagios ./check_nrpe -H 127.0.0.1 -c check_disk
looks like the next step is to add to sudoers file. but i'll be patient and hear what you have to say.
Just to verify I would confirm you can run this as the nagios user first:
sudo su nagios -c "/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/sda1"
majed
Post by majed »
:~$ cd /usr/lib/nagios/plugins/
:/usr/lib/nagios/plugins$ ./check_disk -w 20% -c 10% -p /dev/sda1
DISK OK - free space: / 6835 MB (70% inode=82%);| /=2819MB;8156;9176;0;10196
:/usr/lib/nagios/plugins$ sudo su nagios -c "/check_disk -w 20% -c 10% -p /dev/sda1"
no output from the command!
what does this mean?
The path in your command doesn't look right so try running this example using the full path to the plugin.
sudo su nagios -c "/usr/lib/nagios/plugins/check_disk/check_disk -w 20% -c 10% -p /dev/sda1"
If an error is generated when you run it, post it here so we can view it.
One thing to check is to see if the nagios user account can access the folders the plugins are located in and that it can execute the plugins themselves.
The error you are receiving could be caused by that.
majed
Post by majed »
Peace, I was on a long sick leave.
DISK OK - free space: / 6770 MB (70% inode=82%);| /=2885MB;8156;9176;0;10196
:~$ /usr/lib/nagios/plugins/check_disk  -w 20% -c 10% -p /dev/sda1
:~$ sudo -i -u nagios
:~$ sudo su nagios -c "/usr/lib/nagios/plugins/check_disk  -w 20% -c 10% -p /dev/sda1"
i tried su - nagios but it keeps saying the password is wrong, while sudo -i -u nagios did not ask for a password. is your suspicion correct?
I think the issue is that the nagios useraccount has a password set to it or it is expired and that is causing the issue.
Login to that server as root and run the following to remove the password and to set the account to not expire.
passwd --delete nagios
chage -I -1 -m 0 -M 99999 -E -1 nagios
The nagios user account cannot have a password so hopefully this will fix the issue.
