This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
kadaw978
Posts: 27 Joined: Mon Feb 29, 2016 1:58 pm
Post
by kadaw978 » Fri Jul 07, 2017 2:28 pm
Hi
I'm currently using NagiosXi 5.2.9 and NSCLIENT++ 0.5.0.62.
I'm trying to monitor a directory for a certain file type that is older than "X" minutes. The check that I'm currently using is, but it looks like the pattern option is deprecated and ignored. Is there another way for me to monitor this?
$USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -c CheckFiles -a path=$ARG1$ pattern=$ARG2$ 'filter=written < $ARG3$' MaxCrit=1 'syntax=%filename%: %write%'
I also tried this, but looks like it only checks for a single file.
$USER1$/check_nt -H 192.168..... -s "$ARG1$" -p 12489 -v FILEAGE -l "C:\test.txt" -w 45 -c 60
Posts: 9190 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Fri Jul 07, 2017 3:11 pm
Try this example and see if it works for you.
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -t 30 -c check_files -a path='C:\\Temp\\' pattern=*.* 'filter=written < -5m' 'critical=count>0' top-syntax='${status}: ${problem_count}/${count} files' 'empty-state=ok'
I am running a fairly new version of the 4.x.x and not 5.x but you can see if it works for you.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
kadaw978
Post
by kadaw978 » Fri Jul 07, 2017 3:19 pm
tgriep wrote: Try this example and see if it works for you.
I tried that command and its not returning any output. Nothing in the nsclient error log either.
Post
by tgriep » Fri Jul 07, 2017 3:28 pm
That is strange, it should return something.
Can you post what you ran?
kadaw978
Post
by kadaw978 » Mon Jul 10, 2017 10:28 am
tgriep wrote: That is strange, it should return something.
This is what I ran. No output. Is it possible that my nsclient.ini file configurations is incorrect?
COMMAND: check_nrpe -H xxx.xxx.xx.xxx-t 30 -c check_files -a path='E:\Apps\Test\' pattern=*.xml 'filter=written > -5m' 'critical=count>0' top-syntax='${status}: ${problem_count}/${count} files' 'empty-state=ok'
OUTPUT:
; TODO
[/settings/default]
allowed hosts = xxx.xxx.xx.xxx
; TODO
[/settings/NRPE/server]
;ssl options = no-sslv2,no-sslv3
;verify mode = peer-cert
insecure = true
allow arguments = 1
allow nasty characters = 1
port = 5666
; TODO
[/modules]
CheckExternalScripts = 1
CheckHelpers = 1
CheckEventLog = 1
CheckNSCP = 1
CheckDisk = 1
CheckSystem = 1
NRPEServer = 1
NRPEClient = 1
NSClientServer = 1
Post
by tgriep » Mon Jul 10, 2017 10:59 am
Even it the NSClient++ agent is not running or misconfigured, the plugin should return some sort of output.
Also, in your command, you are missing some escaping needed for the path definition.
Try running this command like below
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -t 30 -c check_files -a path='E:\\Apps\Test\\' pattern=*.xml 'filter=written > -5m' 'critical=count>0' top-syntax='${status}: ${problem_count}/${count} files' 'empty-state=ok'
If it fails, post the output from it as well as the output from the following 2 commands.
kadaw978
Post
by kadaw978 » Mon Jul 10, 2017 1:03 pm
So, running it from the command line yields expected results. However, when I test this check/command through NagiosXI GUI I get no output and the following error, which doesn't make sense since the plugin does exist.
(Return code of 127 is out of bounds - plugin may be missing)
./check_nrpe -H xxx.xxx.xx.xxx -t 30 -c check_files -a path='E:\\Apps\\Test\\' pattern=*.xml 'filter=written < -5m' 'critical=count>0' top-syntax='${status}: ${problem_count}/${count} files' 'empty-state=ok'
CRITICAL: 0/60 files|'count'=60;0;0
I (0.5.0.62 2016-09-14) seem to be doing fine...
kadaw978
Post
by kadaw978 » Mon Jul 10, 2017 1:09 pm
Nvm, I had to add the full path to the plugin for that command to get it to work. Let me see if the check is what I want. Close to closing this ticket.
I'm currently using this command, but it is recursively checking sub folder as well. Can you have a check that only checks a specific directory for a file type of *.txt that is >5 minutes old? Also, the output is returning something like CRITICAL CRITICAL: 0/3 files, shouldn't it be CRITICAL: 3/3 files?
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xx.xxx -t 30 -c check_files -a path='E:\\Apps\\Test\\' pattern=*.txt 'filter=written < -5m' 'critical=count>0' 'empty-state=critical'
Post
by tgriep » Mon Jul 10, 2017 1:54 pm
When using the Test Check command button, sometimes it adds too much escaping to the command causing it to fail so create the command and check it under the Home > Service Details screen to see if it works.
I found this on the NSClient++ web site. Add the following to the command
that will limit the recursion for the folders to 1.
https://docs.nsclient.org/0.5.0/samples/index.html
kadaw978
Post
by kadaw978 » Mon Jul 10, 2017 2:07 pm
Thanks for all your help.
