HTTP 500 error
rwaldron
HTTP 500 error
Post by rwaldron »
Hi all, I have just installed nagios core 3.3.1.. on Ubuntu server
All looks perfect except when I browse to the home link I get page cannot be dispalyed error HTTP 500 ?
All other links in nagios ae fine !
While installing I ran the command /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
I received an error in nagios.cfg line 465.
This was sorted by creating the 2 directories that were missing
ie:
mkdir /usr/local/nagios/var/spool
mkdir /usr/local/nagios/var/spool/checkresults
chown -R nagios:nagios /usr/local/nagios
So I have no errors now but my home page still has http: 500 error.
Any ideas how to sort this ?
Ray..
jsmurphy
Re: HTTP 500 error
Post by jsmurphy »
Hmmm, check /usr/local/nagios/share for permissions problems... they should all belong to the nagios user, also check /usr/local/nagios/sbin
It sounds like it didn't install properly and it might just be easier to recompile it and try again the install again watching carefully for errors.
rwaldron
Re: HTTP 500 error
Post by rwaldron »
I finally got this working (Maps and Homepage ) by downloading the files on a seperate PC and putting them on usb harddisk
Then mount the HD on ubuntu server and copy to server
Then use the quick guide..
The files I was downloading using apt-get must have been corrupt or just not right..
Thx for the reply
rwaldron
Re: HTTP 500 error
Post by rwaldron »
Hiya all,
I got Nagios installed v 3.2.3 without any problems.
When I upgrade to 3.3.1 my home page still gives the HTTP: 500 error..
Is this something to do with the fact that main.html,side.html,index.html are supposed to be replaced by php equivalents and for some reason my update is not changing to php for indes page ?
Ray..
jsmurphy
Re: HTTP 500 error
Post by jsmurphy »
You are correct they should be php files... I still think you should go with my original suggestion of compiling from the source... you will probably find it much less painful ;)
http://www.nagios.org/download/core/thanks/
http://nagios.sourceforge.net/docs/3_0/quickstart.html
rwaldron
Re: HTTP 500 error
Post by rwaldron »
Hiya js and thx so far for the help.
On a fresh copy of ubuntu server I can install nagios 3.2.3 no problem by following the quick guide here http://nagios.sourceforge.net/docs/3_0/ ... buntu.html
If I do another fresh install of ubuntu server and follow the same quick start guide for 3.3.1 then I get the line 465 error as described in my original post.
This can be fixed by running the appropriate chown and chmod and creating the missing directory /usr/local/nagios/var/spool/checkresults.
But my home page still gives the http: 500 error.
Is there a difinitive install guide for Nagios 3.3.1 as I feel that the quick start guide on the nagios site is missing some steps if you are trying to install v 3.3.1 from source.
or is there an easier way to install 3.3.1 not from source ?
Any more help appretiated or will I just stick with ver 3.2.3 for now ?
Ray..
jsmurphy
Re: HTTP 500 error
Post by jsmurphy »
This guide may be a bit better: http://www.unixmen.com/linux-tutorials/ ... 9x-and-10x
Beyond that I'm not sure what else I can suggest, we use SLES, RHEL, CentOS and I've always preferred SuSE to Ubuntu myself as a desktop OS so I'm not particularly familiar with it I'm afraid to know what might be the root cause.
crfriend
Re: HTTP 500 error
Post by crfriend »
In cases where 500-series errors are being returned from the web-server, the web-server logs are usually indespensible for identifying what went bang. Frequently they not only point to the script that failled but sometimes to the exact line, especially if one is using perl or other interpreted scripts.
