File Check Monitoring Threshold problem
twistedfirestarter
Post by twistedfirestarter »
My company are trialing Nagios XI and I want to setup some file check monitoring.
I require a monitor that will show Critical if a file is not present in a given Linux directory.
(I already have working nagios monitors for the same file, regarding file size and age).
check_file_service!-C 'ssh nagios@$HOSTADDRESS$ ls -l /dirname' -F 'filename*' -T 'files'! -w >1 -c <1
This, and other combinations, are failing with an error that advises that the threshold requirements are that -w needs to be lower than -c. I haven't been able to get a 'Critical' for file absence.
Any advise welcome. Thank you.
Re: File Check Monitoring Threshold problem
Try changing this:
to this:
check_file_service!-C 'ssh nagios@$HOSTADDRESS$ ls -l /dirname' -F 'filename*' -T 'files'! -w 1 -c 1:
See more about thresholds and ranges here: https://nagios-plugins.org/doc/guidelin ... HOLDFORMAT
