Hi All,
Any one help me , to change last 24h in below syntax
Nsclient version : I (0.5.0.62 2016-09-14)
$USER1$/check_nrpe -H $HOSTADDRESS$ -c check_eventlog -a file="Application" "warning=count = 1" "critical=count = 3" "filter=source like 'Application Error' AND id = '1000'" unique truncate-message=300 'top-syntax=The status is: ${status}: with ${count} entries matching the ID the last 24h Log message:"${list}"'
Windows event log with nrpe
Re: Windows event log with nrpe
Here's the docs for the NSClient++ CheckEventLog module:
https://docs.nsclient.org/reference/win ... kEventLog/
What exactly do you want to change it to? You should be able to make the status output whatever you like with the top-syntax argument. It's just for display purposes.
If you want to change the actual time frame in which the search happens, you should be able to use the scan-range argument. There's a sample usage on the above documentation page.
Thanks @mcapra for the help.
@gopinathnagios, let us know if you have any further questions in this issue.
gopinathnagios
Thank you @mcapra and @tgriep......
I resolved with top-syntax and scan-range arguments .
Thanks for reporting back. Shall I mark the post as solved and lock it?
gopinathnagios
Yes,
you can lock the post
bolson
Closing topic as resolved.
Thank you for using the Nagios Support Forum.
