check_http errors after update
SnakeMind
Post by SnakeMind »
Goodmorning,
After Nagios plugins got updated last night using epel-testing, the check_http seems to be broken.
Every device with a check_http is now in either socket timeout status or in a critical status like
HTTP CRITICAL - Invalid HTTP response received from host on port 8443: HTTP/1.1 400 Bad Request
This is the only plugin that is not working at this moment, and since it is a freshly updated plugin in the test phase, i thought I wanted to reach out. Anyone any idea what can be wrong?
cdienger
Re: check_http errors after update
Post by cdienger »
Can you post the complete check_http command that you're using? Something about the request being made is upsetting the destination.
Verify the check_http version from the cli with:
/usr/local/nagios/libexec/check_http --version
The latest plugins(2.2.1) release can be found at https://nagios-plugins.org/ . I would recommend upgrading the plugins if they are not at this version.
SnakeMind
Post by SnakeMind »
sorry for the late reply, this was with the 2.2.1-git2.el7 version, with just the --check-version command you'll only get 2.2.1 :)
With version 2.2.1-1.el7 installed there is nothing wrong and it works like a charm, like said, when using the epel-testng branch that includes 2.2.1-git2.el7 it fails.
Hope this helps and gets it resolved :)
Post by dwhitfield »
First of all, we have no control over what epel puts in their repo. You may want to file a bug with them (or compile from our source so we can fix the bug ourselves).
More to the point, we still need to see the actual command that is failing. Please show us what is generating the following:
If the timeout commands look different, please also show us that.
whereisaaron
Post by whereisaaron »
Since upgraded in to check_http 2.2.1 there are a few problems with '--no-body'. E.g. it no longer works in combined with '--expect'. If you remove the '--no-body' option the test will work again.
So if you have any HTTP header tests using both '--expect' and '--no-body', remove the '--no-body' to work around this new bug.
Thanks @whereisaaron for the help.
@SnakeMind let us know if you have any further questions.
cincia
Post by cincia »
Where do you plan to release the new update?
To want to, is to be able to.
All new versions are released at https://github.com/nagios-plugins/nagios-plugins
Compile instructions available at https://support.nagios.com/kb/article.php?id=569
