how to enable mrtg with nagios core 4.1.1
eranki
Post by eranki »
Hi All,
Can someone please help me configure/enable mrtg with nagios core 4.1.1 which is running on centOS-7.1 as i need to monitor CPU,load on the client VM's which is also running on centOS 7.
Please help me with exact documentation or any link?
Raghu
Re: how to enable mrtg with nagios core 4.1.1
MRTG is a tool you would use to measure bandwidth of an ethernet port and not for CPU Usage, load, etc.
If the guests are running under VMWare, you can use this plugin to monitor CPU Usage, Memory, etc
https://exchange.nagios.org/directory/P ... pi/details
Or you can install the NRPE agent on the remote server's and use the check_nrpe plugin on the nagios server to monitor the remote hosts.
https://support.nagios.com/kb/article/n ... ource.html
https://exchange.nagios.org/directory/A ... or/details
Either of those should work for you.
