Nasiosxi repo out of date
escanlan
Post by escanlan »
While following directions on https://repo.nagios.com/ on both CentOS 6 and 7 installations the following behavior is observed.
CENTOS/RHEL 6
rpm -Uvh https://repo.nagios.com/nagios/6/nagios ... noarch.rpm
yum install nagiosxi -y
CENTOS/RHEL 7
rpm -Uvh https://repo.nagios.com/nagios/7/nagios ... noarch.rpm
After running the commands, installation of Nagiosxi version 4.4 is installed even though version 4.6 exists on the http://repo.nagios.com directory:
Installing:
nagiosxi x86_64 5-4.4.el6 nagios-base 51 M
Installing for dependencies:
nagiosxi-ajaxterm x86_64 5-4.4.el6 nagios-base 83 k
nagiosxi-mrtg x86_64 5-4.4.el6 nagios-base 268 k
nagiosxi-nagioscore x86_64 5-4.4.el6 nagios-base 5.5 M
nagiosxi-nagiosmobile x86_64 5-4.4.el6 nagios-base 121 k
nagiosxi-nagiosplugins x86_64 5-4.4.el6 nagios-base 3.2 M
nagiosxi-nagiosql x86_64 5-4.4.el6 nagios-base 894 k
nagiosxi-nagvis x86_64 5-4.4.el6 nagios-base 1.9 M
nagiosxi-ndoutils x86_64 5-4.4.el6 nagios-base 227 k
nagiosxi-nrds x86_64 5-4.4.el6 nagios-base 22 M
nagiosxi-nrpe x86_64 5-4.4.el6 nagios-base 66 k
nagiosxi-nsca x86_64 5-4.4.el6 nagios-base 43 k
nagiosxi-pnp x86_64 5-4.4.el6 nagios-base 32 k
nagiosxi-wkhtmltox x86_64 5-4.4.el6 nagios-base 29 M
nagiosxi-wmic x86_64 5-4.4.el6 nagios-base 6.5 M
It appears that the createrepo command needs to be re-run on the nagios site.
Re: Nasiosxi repo out of date
We are looking in to the issue with the repo being out of date. It should be rebuilt soon so check back tomorrow to see if you can get the newer version of XI to install.
