How to increase log events currently showing only 250
amuzaffar
Post by amuzaffar »
Hi Support, we are in process of purchasing the Nagios Syslog Server, on the trial version we are getting only 250 logs, how to increase the number of logs display to maximum as 250 events are not even more than 10 minutes duration.
Please advise.
cdienger
Re: How to increase log events currently showing only 250
Post by cdienger »
You can increase the number of events you can page through by clicking the Config button in the Events section and then edit the settings found on the Paging tab.
