NRPE Output Size
ssoliveira
NRPE Output Size
Post by ssoliveira »
Good evening,
My graphics are having problems because information is being truncated by check_nrpe.
Calling the command locally is returning correctly.
 [root@datalog-ugt-log1 libexec]# /usr/bin/check_elasticsearch
Monitoring cluster 'a5726a09-769e-4f2b-be91-d786c8165c6f' | cluster_nodes=4;;;;; cluster_master_eligible_nodes=4;;;;; cluster_data_nodes=4;;;;; cluster_active_shards=1038;;;;; cluster_relocating_shards=0;;;;; cluster_initialising_shards=0;;;;; cluster_unassigned_shards=0;;;;; cluster_total_shards=1038;;;;; cluster_total_indices=70;;;;; cluster_closed_indices=0;;;;; storesize=2124557370946B;;;;; documents=1920168754c;;;;; index_ops=737278752c;;;;; index_time=322062338ms;;;;; flush_ops=9641c;;;;; flush_time=1228456ms;;;;; throttle_time=217690564ms;;;;; index_ops=737278752c;;;;; index_time=322062338ms;;;;; delete_ops=198c;;;;; delete_time=57ms;;;;; get_ops=630539c;;;;; get_time=106761ms;;;;; exists_ops=630536c;;;;; exists_time=106761ms;;;;; missing_ops=3c;;;;; missing_time=0ms;;;;; query_ops=1418392c;;;;; query_time=86096168ms;;;;; fetch_ops=1158580c;;;;; fetch_time=575445ms;;;;; merge_ops=362208c;;;;; refresh_ops=1825688c;;;;; refresh_time=60179314ms;;;;; gc_old_count=21995c;;;;; gc_young_count=185113c;;;;; heap_used=74%;;;;;
However, calling via check_nrpe, it is truncating after the character 1024
[root@datalog-ugt-log1 libexec]# ./check_nrpe -H 127.0.0.1 -t 90 -c check_elasticsearch
Monitoring cluster 'a5726a09-769e-4f2b-be91-d786c8165c6f' | cluster_nodes=4;;;;; cluster_master_eligible_nodes=4;;;;; cluster_data_nodes=4;;;;; cluster_active_shards=1038;;;;; cluster_relocating_shards=0;;;;; cluster_initialising_shards=0;;;;; cluster_unassigned_shards=0;;;;; cluster_total_shards=1038;;;;; cluster_total_indices=70;;;;; cluster_closed_indices=0;;;;; storesize=2124552989529B;;;;; documents=1920159721c;;;;; index_ops=737269359c;;;;; index_time=322057667ms;;;;; flush_ops=9641c;;;;; flush_time=1228456ms;;;;; throttle_time=217688412ms;;;;; index_ops=737269359c;;;;; index_time=322057667ms;;;;; delete_ops=198c;;;;; delete_time=57ms;;;;; get_ops=630518c;;;;; get_time=106757ms;;;;; exists_ops=630515c;;;;; exists_time=106757ms;;;;; missing_ops=3c;;;;; missing_time=0ms;;;;; query_ops=1418362c;;;;; query_time=86087807ms;;;;; fetch_ops=1158557c;;;;; fetch_time=575429ms;;;;; merge_ops=362199c;;;;; refresh_ops=1825662c;;;;; refresh_time=60177868ms;;;;; gc_old_count=21992c;;;;; gc_young_count=185110c;;;;; he
Apparently there is a limit on the amount of characters processed.
How can I configure NRPE to return the complete string?
Incorrect command line arguments supplied
NRPE Plugin for Nagios
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 2.15
Last Modified: 09-06-2013
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher required
Re: NRPE Output Size
Version 2.15 of the NRPE agent and plugin does have a limit in the amount of data that is sent in the buffer but the newer 3.x.x version has increased the size of the buffer that transfers the data so it should not get cut off.
You would have to recompile the Agent and the plugin for this to work and the instructions for doing that can be found here.
https://support.nagios.com/kb/article/n ... ource.html
ssoliveira
Thank you very much
bolson
Post by bolson »
Is it ok if we go ahead and close this?
