Nagios XI stopped monitoring after a particular date. Kindly help.
Nagios XI monitoring stops after a particular date
support.lta
Re: Nagios XI monitoring stops after a particular date
Can you please provide more information?
- What XI version are you using?
- What OS and version is it installed on?
- How long ago did this start?
- Is it just not sending emails or is it not monitoring at all?
support.lta
What XI version are you using? --> Ans: Nagios XI Enterprise
What OS and version is it installed on? --> Ans: RHEL 7.2
How long ago did this start? --> Ans: 1 month
Is it just not sending emails or is it not monitoring at all? --> Ans: Both, it is not sending any notifications, as we tried to triggered it and stopped our application services but no notification from Nagios.
Can you please tell me the version of Nagios XI that you are running? It will be in the bottom-left of your screen after you log in. It will look something like 5.4.12 or 2014R3.4.
support.lta
Hi, thanks for looking into this it is version: Nagios XI 5.2.9
Please send the output of these commands:
Then PM one of us a copy of your profile, you can download it by going to Admin > System Config > System Profile and click the Download Profile button in the top right corner.
Then run these commands and it may get it up and running properly for you:
Test after that.
Thank you
df -h
df -i
chage -l nagios
tail -n100 /var/log/messages /var/log/httpd/*error_log /var/log/mysqld.log /var/log/mariadb/mariadb.log /var/log/maillog /usr/local/nagiosxi/tmp/phpmailer.logThen run these commands and it may get it up and running properly for you:
service npcd stop
service nagios stop
service ndo2db stop
service postgresql stop
service mysqld restart
rm -rf /usr/local/nagios/var/rw/nagios.cmd
rm -rf /usr/local/nagios/var/nagios.lock
rm -rf /usr/local/nagios/var/ndo.sock
rm -rf /usr/local/nagios/var/ndo2db.lock
rm -rf /usr/local/nagiosxi/var/reconfigure_nagios.lock
rm -rf /var/lib/mrtg/mrtg_l
for i in `ipcs -q | grep nagios |awk '{print $2}'`; do ipcrm -q $i; done
pkill -9 -u nagios
service httpd restart
service postgresql start
service ndo2db start
service nagios start
service npcd start
service crond restartThank you
