No new perfdata in graphs
jvestrum
Post by jvestrum »
Our /var/nagiosramdisk filled up a couple weeks ago. I recreated the ramdisk this morning with more space and migrated the contents over, however none of our host/service graphs are getting updated. They still have the old data if I set the span to 30 days but nothing from today. Npcd is running as is the /usr/local/nagiosxi/cron/perfdataproc.php cron job. The perfdataproc.log is filled with lines like these:
DONE. Processed 0 files.
Outbound data DISABLED Mon, 17 Jul 2017 14:35:05 -0500
Outbound data DISABLED Mon, 17 Jul 2017 14:36:05 -0500
Outbound data DISABLED Mon, 17 Jul 2017 14:37:03 -0500
Outbound data DISABLED Mon, 17 Jul 2017 14:38:04 -0500
Outbound data DISABLED Mon, 17 Jul 2017 14:39:04 -0500
It's always "Processed 0 files". /var/nagiosramdisk/host-perfdata and service-perfdata slowly grow, then go back down to zero every minute, so it seems the data is being processed, but the graphs do not update.
Running the latest XI 5.4.7 and have restarted all the services. Let me know what else would help troubleshoot this.
jvestrum
Re: No new perfdata in graphs
Post by jvestrum »
I think the problem is in /usr/local/nagiosxi/html/config.inc.php and /usr/local/nagiosxi/var/xi-sys.cfg. Both of these had the location of xidpe_dir and perfdata set to the default /usr/local/nagios/var/spool. I changed them to point to /var/nagiosramdisk/spool and perfdataproc.php is chewing on the data right now. This will take a while, once it's done I'll see if the graphs are fixed.
ssax
Dreams In Code
Post by ssax »
Please run through this KB article and see if you can identify the problem:
https://support.nagios.com/kb/article/n ... blems.html
Here is the architecture overview so that you can familiarize yourself with it:
https://support.nagios.com/kb/article/n ... cture.html
Please attach these files so that we can review them for any mistakes:
/etc/init.d/nagios
/etc/sysconfig/nagios
/usr/local/nagios/etc/nagios.cfg
/usr/local/nrdp/server/config.inc.php
/usr/local/nagios/etc/pnp/npcd.cfg
/usr/local/nagiosmobile/include.inc.php
/usr/local/nagios/etc/commands.cfg
Then send the output of these commands:
chage -l nagios
service npcd status
top -n3
cat /etc/sudoers
tail /usr/local/nagios/var/npcd.log /usr/local/nagios/var/perfdata.log /usr/local/nagiosxi/var/process_perfdata.pl
jvestrum
Post by jvestrum »
Thanks for the pointers! After fixing the paths in those config files the graphs are working again.
bolson
Post by bolson »
May we go ahead and close this thread?
jvestrum
Post by jvestrum »
Yes, go ahead and close it. Thanks.
bolson
Post by bolson »
Closing this topic as resolved. Thank you!
