We are facing space issue on our NagiosXi server and I could see lot of files getting created. Could you please help us address this issue. I am not sure whether they can be deleted. What would be the better approach for housekeeping the same.
/var/lib/mysql/nagios/nagios_statehistory.MYD: 2.9G
/var/cache/logwatch/logwatch.zSatm_u6/messages: 1.7G
/var/lib/mysql/nagios/nagios_logentries.TMD: 1.5G
/var/lib/mysql/nagios/nagios_logentries.MYD: 1.5G
/store/backups/postgresql/daily/nagiosxi/nagiosxi_2017-07-18.Tuesday.sql.gz: 1.5G
/var/lib/pgsql/data/base/16385/266970: 1.0G
/var/lib/pgsql/data/base/16385/266968: 1.0G
/var/lib/pgsql/data/base/16385/266967: 1.0G
/var/lib/pgsql/data/base/16385/266966.1: 1.0G
/var/lib/pgsql/data/base/16385/266966: 1.0G
/var/lib/pgsql/data/base/16385/266965: 1.0G
/var/lib/pgsql/data/base/16385/266963.9: 1.0G
/var/lib/pgsql/data/base/16385/266963.83: 1.0G
/var/lib/pgsql/data/base/16385/266963.82: 1.0G
/var/lib/pgsql/data/base/16385/266963.81: 1.0G
/var/lib/pgsql/data/base/16385/266963.8: 1.0G
/var/lib/pgsql/data/base/16385/266963.80: 1.0G
/var/lib/pgsql/data/base/16385/266963.79: 1.0G
/var/lib/pgsql/data/base/16385/266963.78: 1.0G
/var/lib/pgsql/data/base/16385/266963.77: 1.0G
/var/lib/pgsql/data/base/16385/266963.76: 1.0G
/var/lib/pgsql/data/base/16385/266963.75: 1.0G
/var/lib/pgsql/data/base/16385/266963.74: 1.0G
/var/lib/pgsql/data/base/16385/266963.73: 1.0G
/var/lib/pgsql/data/base/16385/266963.72: 1.0G
/var/lib/pgsql/data/base/16385/266963.71: 1.0G
/var/lib/pgsql/data/base/16385/266963.7: 1.0G
/var/lib/pgsql/data/base/16385/266963.70: 1.0G
/var/lib/pgsql/data/base/16385/266963.69: 1.0G
/var/lib/pgsql/data/base/16385/266963.68: 1.0G
/var/lib/pgsql/data/base/16385/266963.67: 1.0G
/var/lib/pgsql/data/base/16385/266963.66: 1.0G
/var/lib/pgsql/data/base/16385/266963.65: 1.0G
/var/lib/pgsql/data/base/16385/266963.64: 1.0G
/var/lib/pgsql/data/base/16385/266963.63: 1.0G
/var/lib/pgsql/data/base/16385/266963.62: 1.0G
/var/lib/pgsql/data/base/16385/266963.61: 1.0G
/var/lib/pgsql/data/base/16385/266963.6: 1.0G
/var/lib/pgsql/data/base/16385/266963.60: 1.0G
/var/lib/pgsql/data/base/16385/266963.59: 1.0G
/var/lib/pgsql/data/base/16385/266963.58: 1.0G
/var/lib/pgsql/data/base/16385/266963.57: 1.0G
/var/lib/pgsql/data/base/16385/266963.56: 1.0G
/var/lib/pgsql/data/base/16385/266963.55: 1.0G
/var/lib/pgsql/data/base/16385/266963.54: 1.0G
/var/lib/pgsql/data/base/16385/266963.53: 1.0G
/var/lib/pgsql/data/base/16385/266963.52: 1.0G
/var/lib/pgsql/data/base/16385/266963.51: 1.0G
/var/lib/pgsql/data/base/16385/266963.5: 1.0G
/var/lib/pgsql/data/base/16385/266963.50: 1.0G
/var/lib/pgsql/data/base/16385/266963.49: 1.0G
/var/lib/pgsql/data/base/16385/266963.48: 1.0G
/var/lib/pgsql/data/base/16385/266963.47: 1.0G
/var/lib/pgsql/data/base/16385/266963.46: 1.0G
/var/lib/pgsql/data/base/16385/266963.45: 1.0G
/var/lib/pgsql/data/base/16385/266963.44: 1.0G
/var/lib/pgsql/data/base/16385/266963.43: 1.0G
/var/lib/pgsql/data/base/16385/266963.42: 1.0G
/var/lib/pgsql/data/base/16385/266963.41: 1.0G
/var/lib/pgsql/data/base/16385/266963.4: 1.0G
/var/lib/pgsql/data/base/16385/266963.40: 1.0G
/var/lib/pgsql/data/base/16385/266963.39: 1.0G
/var/lib/pgsql/data/base/16385/266963.38: 1.0G
/var/lib/pgsql/data/base/16385/266963.37: 1.0G
/var/lib/pgsql/data/base/16385/266963.36: 1.0G
/var/lib/pgsql/data/base/16385/266963.35: 1.0G
/var/lib/pgsql/data/base/16385/266963.34: 1.0G
/var/lib/pgsql/data/base/16385/266963.33: 1.0G
/var/lib/pgsql/data/base/16385/266963.32: 1.0G
/var/lib/pgsql/data/base/16385/266963.31: 1.0G
/var/lib/pgsql/data/base/16385/266963.3: 1.0G
/var/lib/pgsql/data/base/16385/266963.30: 1.0G
/var/lib/pgsql/data/base/16385/266963.29: 1.0G
/var/lib/pgsql/data/base/16385/266963.28: 1.0G
/var/lib/pgsql/data/base/16385/266963.27: 1.0G
/var/lib/pgsql/data/base/16385/266963.26: 1.0G
/var/lib/pgsql/data/base/16385/266963.25: 1.0G
/var/lib/pgsql/data/base/16385/266963.24: 1.0G
/var/lib/pgsql/data/base/16385/266963.23: 1.0G
/var/lib/pgsql/data/base/16385/266963.22: 1.0G
/var/lib/pgsql/data/base/16385/266963.21: 1.0G
/var/lib/pgsql/data/base/16385/266963.2: 1.0G
/var/lib/pgsql/data/base/16385/266963.20: 1.0G
/var/lib/pgsql/data/base/16385/266963.19: 1.0G
/var/lib/pgsql/data/base/16385/266963.18: 1.0G
/var/lib/pgsql/data/base/16385/266963.17: 1.0G
...skipping 43 lines
/usr/local/nagios/share/perfdata/dalcjdaq00.fossil.com/Tablespace_SYSTEM_Usage.rrd: 115M
/usr/lib/oracle/11.2/client64/lib/libociei.so: 114M
tail -100 event_handler.log
eventqueue_id ] => 2534391
[ 0 ] => [25752331
] => 1500181494
[ eventqueue_id ] => [2575233event_time
] => 1500181494
[ 1 ] => [15002892202
] => 2
[ event_time ] => 1500289220
[ event_source ] => 2
[ 2 ] => 2
[ 3 ] => 1
[ event_type ] => 1
[ 3 ] => 2
[ 4 ] => 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
[ event_type ] => 2
[ event_meta ] => 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
4] => 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
[event_meta] => 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
Array
[0] => 2546380
[eventqueue_id] => 2546380
[1] => 1500210033
[event_time] => 1500210033
Array
[ 2 ] => [2
0Array
2554301 [ event_source ] => 2[
0 ] => 2586512
[3 ] => [2 eventqueue_id
] => [ 2554301eventqueue_id
] => Array
2586512 (
[ event_type ] => 2
[ 1[[10] => ] => 1500322848] => 2543962
1500210077
[ Array
eventqueue_id[[] => 2543962
4event_time [ ] => event_time[1500322848] => 01] =>
] => ] => 150021001825940581500210077
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
event_time[] => [ 21500210018] =>
eventqueue_id ] => 2594058[
22
] => [2[21
] => ] => [2 event_source1500366291] => [
2event_meta
] => [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
event_source
] => 2[ event_time
[] => event_source1500366291 [
3 ] => [ 3 ] => [22
] => 2
[ event_type ] => [2event_source
] => 2
[ 4 ] => [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3
] => ] => 2Array
2
[ event_meta ] => [[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30] => ] =>
25410122)
[ [ eventqueue_idevent_type] => ] => [22541012event_type
] => 2
[ 4 ] => [[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
] => ] => 1500210000YToyNzp7czoxNzoibm90aWZpY2F0aW9uLXR5cGUiO3M6Nzoic2VydmljZSI7czo3OiJjb250YWN0IjtzOjExOiJuYWdpb3NhZG1pbiI7czoxMjoiY29udGFjdGVtYWlsIjtzOjE2OiJuYWdpb3NAbG9jYWxob3N0IjtzOjQ6InR5cGUiO3M6NzoiUFJPQkxFTSI7czo5OiJlc2NhbGF0ZWQiO3M6MToiMCI7czo2OiJhdXRob3IiO2I6MDtzOjg6ImNvbW1lbnRzIjtiOjA7czo0OiJob3N0IjtzOjUyOiJkYWxjYml3cDMwLmZvc3NpbC5jb21fMTcyLjMwLjI0OC4xMDBfR29sZF9WaXJ0dWFsX05BIjtzOjExOiJob3N0YWRkcmVzcyI7czoxNDoiMTcyLjMwLjI0OC4xMDAiO3M6OToiaG9zdGFsaWFzIjtzOjUyOiJkYWxjYml3cDMwLmZvc3NpbC5jb21fMTcyLjMwLjI0OC4xMDBfR29sZF9WaXJ0dWFsX05BIjtzOjE1OiJob3N0ZGlzcGxheW5hbWUiO3M6NTI6ImRhbGNiaXdwMzAuZm9zc2lsLmNvbV8xNzIuMzAuMjQ4LjEwMF9Hb2xkX1ZpcnR1YWxfTkEiO3M6Nzoic2VydmljZSI7czoxMjoiTWVtb3J5IFVzYWdlIjtzOjk6Imhvc3RzdGF0ZSI7czoyOiJVUCI7czoxMToiaG9zdHN0YXRlaWQiO3M6MToiMCI7czoxMjoic2VydmljZXN0YXRlIjtzOjg6IkNSSVRJQ0FMIjtzOjE0OiJzZXJ2aWNlc3RhdGVpZCI7czoxOiIyIjtzOjE2OiJsYXN0c2VydmljZXN0YXRlIjtzOjg6IkNSSVRJQ0FMIjtzOjE4OiJsYXN0c2VydmljZXN0YXRlaWQiO3M6MToiMiI7czoxNjoic2VydmljZXN0YXRldHlwZSI7czo0OiJIQVJEIjtzOjE0OiJjdXJyZW50YXR0ZW1wdCI7czoxOiI1IjtzOjExOiJtYXhhdHRlbXB0cyI7czoxOiI1IjtzOjE0OiJzZXJ2aWNlZXZlbnRpZCI7czo4OiIxNDEzOTA2MyI7czoxNjoic2VydmljZXByb2JsZW1pZCI7czo3OiI1NDAwMDczIjtzOjEzOiJzZXJ2aWNlb3V0cHV0IjtzOjMzOiJDUklUSUNBTCAtIDAuOCUgKDc2NzIxNiBrQikgZnJlZSEiO3M6MTc6ImxvbmdzZXJ2aWNlb3V0cHV0IjtiOjA7czo4OiJkYXRldGltZSI7czoyODoiVHVlIEp1bCAxOCAwMzoyNDo1MSBDRFQgMjAxNyI7czoxMzoiaG9zdGdyb3VwbmFtZSI7czoxNToiQUlYX0dvbGRfU2VydmVyIjt9
[ event_meta ] => [ 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_meta[
event_time] => )
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] =>
1500210000)
[2] => 2
[event_source] => 2
[3] => 2
[event_type] => 2
[4] => 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
[event_meta] => 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
1
[event_type] => 1
[4] => 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
[event_meta] => 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
