I would know if it's possible to create an alert based on a SQL request.
For example : a request give me a result of 37 and my alert'll be critical if the result is superior to 40.
If it's possible, i'll search more to find the good way to do that.
Thanks in advance.
SQL Server alert
Re: SQL Server alert
check_mysql_query is included with nagios-plugins:
Depending on what guide you followed to install Nagios Core, you should already have the standard nagios plugins installed. If not, this KB article has a "Installing The Nagios Plugins" section:
https://support.nagios.com/kb/article/n ... ource.html
[root@nagios ~]# /usr/local/nagios/libexec/check_mysql_query -h
check_mysql_query v2.2.1.6.g4103.dirty (nagios-plugins 2.2.1)
Copyright (c) 1999-2014 Nagios Plugin Development Team
<[email protected]>
This program checks a query result against threshold levels
Usage:
check_mysql_query -q SQL_query [-w warn] [-c crit] [-H host] [-P port] [-s socket]
[-d database] [-u user] [-p password] [-f optfile] [-g group]
Options:
-h, --help
Print detailed help screen
-V, --version
Print version information
--extra-opts=[section][@file]
Read options from an ini file. See
https://www.nagios-plugins.org/doc/extra-opts.html
for usage and examples.
-q, --query=STRING
SQL query to run. Only first column in first row will be read
-w, --warning=RANGE
Warning range (format: start:end). Alert if outside this range
-c, --critical=RANGE
Critical range
-H, --hostname=ADDRESS
Host name, IP Address, or unix socket (must be an absolute path)
-P, --port=INTEGER
Port number (default: 3306)
-s, --socket=STRING
Use the specified socket (has no effect if -H is used)
-d, --database=STRING
Database to check
-f, --file=STRING
Read from the specified client options file
-g, --group=STRING
Use a client options group
-u, --username=STRING
Username to login with
-p, --password=STRING
Password to login with
==> IMPORTANT: THIS FORM OF AUTHENTICATION IS NOT SECURE!!! <==
Your clear-text password could be visible as a process table entry
A query is required. The result from the query should be numeric.
For extra security, create a user with minimal access.
Notes:
You must specify -p with an empty string to force an empty password,
overriding any my.cnf settings.
Send email to [email protected] if you have questions regarding use
of this software. To submit patches or suggest improvements, send email to
[email protected]
- Former Nagios Staff
