mod-gearman nothing happening
jkinning
Post by jkinning »
I followed this guide - https://assets.nagios.com/downloads/nag ... ios_XI.pdf and can see the queue information when I run gearman_top2 on my Nagios XI server. What I don't understand is does this get used only when needed? I can't see to get any hosts or service checks to funnel through mod-gearman as this queue appears to be idle? It seemed pretty straight forward but apparently I am missing something or not understanding this process.
I also have read this KB article - https://support.nagios.com/kb/article.php?id=484
cdienger
Re: mod-gearman nothing happening
Post by cdienger »
Do you have a lot of service or host checks to funnel through? Do checks seem to working? After installing gearman the /usr/local/nagios/etc/nagios.cfg you should see a line like:
broker_module=/usr/lib64/mod_gearman2/mod_gearman2.o config=/etc/mod_gearman2/module.conf eventhandler=no
This along with successful checks would be positive signs that all is working.
jkinning
Post by jkinning »
I searched that config and found this.
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
Should I change it or should of it happened when I ran the ModGearmanInstall.sh --type=server
The script should of added the broker module to the nagios.cfg file but you can add it to the bottom of it manually.
Then restart nagios by running the following as root so nagios will start to use that module.
service nagios restart
Try that and post if you have anymore questions.
cdienger
Post by cdienger »
It should be set when you run the script with the code:
if [ "$install_type" == "server" ]; then
        info " "
    /etc/init.d/gearmand start
        sed -i 's/\(^broker_module=.*mod_gearman.*\)/#\1/' $nagios_cfg
        echo -e "\n\nbroker_module=$lib_dir/mod_gearman2/mod_gearman2.o config=/etc/mod_gearman2/module.conf eventhandler=no" >> $nagios_cfg
        /etc/init.d/nagios restart
Was the script run when you were logged in as root?
jkinning
Post by jkinning »
Yes I was root.
[root@nagiosl1t tmp]# wget http://assets.nagios.com/downloads/nagiosxi/scripts/ModGearmanInstall.sh
--2017-07-20 10:42:45--  http://assets.nagios.com/downloads/nagiosxi/scripts/ModGearmanInstall.sh
Resolving assets.nagios.com... 72.14.181.71, 2600:3c00::f03c:91ff:fedf:b821
Connecting to assets.nagios.com|72.14.181.71|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://assets.nagios.com/downloads/nagiosxi/scripts/ModGearmanInstall.sh [following]
--2017-07-20 10:42:45--  https://assets.nagios.com/downloads/nagiosxi/scripts/ModGearmanInstall.sh
Connecting to assets.nagios.com|72.14.181.71|:443... connected.
Length: 11979 (12K) [application/x-sh]
Saving to: “ModGearmanInstall.sh”
100%[=====================================================================================================================================================================>] 11,979      --.-K/s   in 0s
2017-07-20 10:42:45 (92.9 MB/s) - “ModGearmanInstall.sh” saved [11979/11979]
You have new mail in /var/spool/mail/root
[root@nagiosl1t tmp]# chmod +x ModGearmanInstall.sh
[root@nagiosl1t tmp]# ./ModGearmanInstall.sh --type=server
Nagios Enterprises
Mod Gearman Installer Script
License:
    Nagios Open Software License
Support:
    XI Support Mailing List    <[email protected]> (customers only)
    Community Forums           <http://support.nagios.com/forum/>
Notices:
   * Only run this script on a machine with no previous gearman installations
   * Only run this script in server mode if the machine runs Nagios Core 4
   * This script comes with absolutely no warranty, use it at your own risk
    Downloading necessary packages...
--2017-07-20 10:47:14--  http://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-0.33-2.rhel6.x86_64.rpm
Location: https://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-0.33-2.rhel6.x86_64.rpm [following]
--2017-07-20 10:47:14--  https://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-0.33-2.rhel6.x86_64.rpm
Length: 276495 (270K) [application/x-rpm]
Saving to: “gearmand-0.33-2.rhel6.x86_64.rpm”
100%[=====================================================================================================================================================================>] 276,495     1.47M/s   in 0.2s
2017-07-20 10:47:14 (1.47 MB/s) - “gearmand-0.33-2.rhel6.x86_64.rpm” saved [276495/276495]
--2017-07-20 10:47:14--  http://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-devel-0.33-2.rhel6.x86_64.rpm
Location: https://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-devel-0.33-2.rhel6.x86_64.rpm [following]
--2017-07-20 10:47:14--  https://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-devel-0.33-2.rhel6.x86_64.rpm
Length: 201934 (197K) [application/x-rpm]
Saving to: “gearmand-devel-0.33-2.rhel6.x86_64.rpm”
100%[=====================================================================================================================================================================>] 201,934     --.-K/s   in 0.1s
2017-07-20 10:47:15 (1.37 MB/s) - “gearmand-devel-0.33-2.rhel6.x86_64.rpm” saved [201934/201934]
--2017-07-20 10:47:15--  http://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/mod_gearman2-2.1.1-1.rhel6.x86_64.rpm
Location: https://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/mod_gearman2-2.1.1-1.rhel6.x86_64.rpm [following]
--2017-07-20 10:47:15--  https://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/mod_gearman2-2.1.1-1.rhel6.x86_64.rpm
Length: 298743 (292K) [application/x-rpm]
Saving to: “mod_gearman2-2.1.1-1.rhel6.x86_64.rpm”
100%[=====================================================================================================================================================================>] 298,743     1.35M/s   in 0.2s
2017-07-20 10:47:15 (1.35 MB/s) - “mod_gearman2-2.1.1-1.rhel6.x86_64.rpm” saved [298743/298743]
--2017-07-20 10:47:15--  http://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-server-0.33-2.rhel6.x86_64.rpm
Location: https://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-server-0.33-2.rhel6.x86_64.rpm [following]
--2017-07-20 10:47:15--  https://assets.nagios.com/downloads/mod_gearman/v2.1.1/rhel6/x86_64/gearmand-server-0.33-2.rhel6.x86_64.rpm
Length: 122448 (120K) [application/x-rpm]
Saving to: “gearmand-server-0.33-2.rhel6.x86_64.rpm”
100%[=====================================================================================================================================================================>] 122,448     --.-K/s   in 0.1s
2017-07-20 10:47:16 (1.12 MB/s) - “gearmand-server-0.33-2.rhel6.x86_64.rpm” saved [122448/122448]
    Installing the packages...
Starting gearmand:                                         [  OK  ]
Running configuration check...
Stopping nagios:. done.
Starting nagios: done.
Starting mod_gearman2_worker...OK
    Here is some potentially helpful information:
       ModGearman configuration directory:    /etc/mod_gearman2/
       Log files:                             /var/log/mod_gearman2/
       ModGearman Worker:                     /etc/init.d/mod-gearman2-worker
       gearmand Server:                       /etc/init.d/gearmand
    If you want to view the queue statuses, you'll run:
       gearman_top2
    You may need the following iptables rules, as well:
       iptables -I INPUT -p tcp --dport 4730 -j ACCEPT
       iptables -I INPUT -p udp --dport 4730 -j ACCEPT
[root@nagiosl1t tmp]# gearman_top2
ssax
Dreams In Code
Post by ssax »
Please run this command on your XI server and attach the resulting /tmp/xigearman.zip file.
zip -r /tmp/xigearman.zip /etc/mod_gearman2 /var/log/mod_gearman2
Please run this command on your worker and attach the resulting /tmp/workergearman.zip file.
zip -r /tmp/workergearman.zip /etc/mod_gearman2 /var/log/mod_gearman2
Also, please send the output of this command on the XI server:
iptables -L
Thank you
jkinning
Post by jkinning »
[root@nagiosl1t etc]# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
I am running mod-gearman on my XI server. Maybe I am not understanding the workers but isn't it possible to run mod-gearman on the XI server and not need an additional worker machine or do I need a worker machine? I am not starting to get confused.
Overall objective is to try and take some load of my main Nagios XI server to see if I can prevent out of bound messages I am getting from NSClient++ machines.
ssax
Dreams In Code
Post by ssax »
By default it will install the worker and the job server on the XI server.
To offload the processing you will need to spin up another server and only install the worker and the plugins on it and configure it.
Please attach your nagios.cfg and the output of:
gearman_top2
jkinning
Post by jkinning »
See attached.
