how to drop nxlog connection message
pccwglobalit
Post by pccwglobalit »
There are a lot of nxlog permit connection message. Can i set filter in nxlog or logstash to drop such messages ?
The Windows Filtering Platform has permitted a connection.
Application Information:
Process ID: 1788
Application Name: \device\harddiskvolume2\program files (x86)\nxlog\nxlog.exe
Network Information:
Direction: Outbound
Source Address: 192.168.99.2
Source Port: 49158
Destination Address: 192.168.99.12
Destination Port: 3515
Protocol: 6
Filter Information:
Filter Run-Time ID: 229143
Layer Name: Connect
Layer Run-Time ID: 48
tacolover101
Re: how to drop nxlog connection message
Post by tacolover101 »
take a look at the concept here, and apply it accordingly - https://support.nagios.com/forum/viewto ... 24#p224210
if [message] =~ 'Start* Session* *nagios**' {
drop {}
depending how your message field looks you could[/ probably match something like this Layer Name: Connect
Post by mcapra »
If you could share a screenshot of one such event in the Nagios Log Server GUI, fully expanded to show all the fields, that might be helpful for refining the filter rule a bit.
Post by dwhitfield »
Thanks @tacolover101 and @mcapra!
@pccwglobalit, let us know if you need anything additional help!
