Nagios running on CLI but not running on web interface
Nagios is running on CLI but not running on web interface.
pid is there in /usr/local/nagios/var/nagios.lock
- nagios.png (14.3 KiB) Viewed 5538 times
bolson
Re: Nagios running on CLI but not running on web interface
Hello Bumblebee,
Regarding your post from yesterday, were you able to confirm that PHP is installed? What method did you use to install Nagios Core?
I installed php and that issue is resolved.
Later I encountered with pid not running on dashboard issue
bolson
Please send me a copy of your profile, you can download it by going to Admin > System Config > System Profile and click the Download Profile button in the top right corner.
Thank you!
Thank you!
We were using nagios core where there is no admin tab and system config
bolson
Please run the following command and post the result:
ps ax | grep nagios-
bolson
Also the following command and post your result:
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgRe: Nagios running on CLI but not running on web interface
pe ax |grep nagios
15457 ? Ss 2:42 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
15458 ? S 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
15459 ? S 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
15460 ? S 0:02 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
15461 ? S 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
15462 ? S 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
15463 ? S 0:01 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
15464 ? S 0:46 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 8 services.
Checked 1 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 24 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 1 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Checking objects...
Checked 8 services.
Checked 1 hosts.
Checked 1 contacts.
Checked 1 hosts
Total Warnings: 0
Total Errors: 0
bolson
How did you install Nagios? How did you install PHP? Did you use a how-to document? If so, which one? Which operating system / version are you running?
